4管发射机原理图
![]() Circuit Notes This circuit provides an FM modulated signal with an output power of around 500mW. The input Mic preamp is built around a couple of 2N3904 transistors, audio gain limited by the 5k preset. The oscillator is a colpitts stage, frequency of oscillation governed by the tank circuit made from two 5pF capacitors and the inductor. ( Click here for Colpitt Oscillator Resonant Frequency Equation.) Frequency is around 100Mhz with values shown. Audio modulation is fed into the tank circuit via the 5p capacitor, the 10k resistor and 1N4002 controlling the amount of modulation. The oscillator output is fed into the 3.9uH inductor which will have a high impedance at RF frequencies. The output stage operates as a class D amplifier , no direct bias is applied but the RF signal developed across the 3.9uH inductor is sufficient to drive this stage. The emitter resistor and 1k base resistor prevent instability and thermal runaway in this stage. |
1 个讨论
884 浏览 0 评论
3737 浏览 1 评论
6492 浏览 0 评论
TIKOOL太酷信息无线内部通话系统允许多个人一起讲话,频道内会不会很吵?
4675 浏览 0 评论
各位大佬好,我用vco替代rtc6705,得到的图像不稳定是怎么回事啊?
4993 浏览 3 评论
GMT+8, 2025-4-12 10:08 , Processed in 0.744923 second(s), Total 39, Slave 31 queries .
