状态机不稳定,跑上几十次就卡在某个状态。
改成三段式后,在RTL viewer看综合后的电路,综合成了状态机(黄色那块)。 这时候程序运行几遍就会卡住。但是将CS赋值给led变量后,编译后用RTLviewer观察,没有综合出状态机,CS总合成了触发器,这时候程序反而能一直运行下去,不会卡住。 这到底是为什么。。。代码如下(两次编译的区别就在于最下边标红的部分,现在的代码编译没有综合出状态机,将下边那行代替这行,就会编译生成状态机): module DO_backplane( //global signals input clk, input nRST, //DO_trigger module interface //input [7:0] b_feedback, //input [13:0] working_status, output reg [13:0] b_trigger, output reg [13:0] led, //backplane signals input [9:0] b_addr, inout [7:0] b_data, input b_rd, //active low input b_wr, //active low //input retry, //active low output reg ready, //active low output reg [3:0] oe, output reg [3:0] dir ); //FSM is coded by one-hot localparam Bus_Idle =5'h00; localparam Bus_RW =5'h01; localparam Bus_Ready =5'h02;//set ready signal in read cycle localparam Bus_Data =5'h04; localparam Bus_Ready_UN =5'h08; localparam Bus_Finish =5'h10; /* //FSM is coded by Gray Code localparam Bus_Idle =4'b0000; localparam Bus_RW =4'b0001; localparam Bus_Ready =4'b0011;//set ready signal in read cycle localparam Bus_Data =4'b0010; localparam Bus_Ready_UN =4'b0110; localparam Bus_Finish_a =4'b0100; localparam Bus_Finish_b =4'b0101; localparam Bus_Finish_c =4'b0111; localparam Bus_Finish_d =4'b1111; */ //DO1A board base address parameter DO_base_addr =10'h180; //backplane communication reg [4:0] CS; reg [4:0] NS; reg [7:0] data; reg read_flag; reg [13:0] b_trigger_temp; reg [7:0] data_temp; reg [25:0] count; //tri-stated databus assign b_data = (~read_flag)?data:8'hzz; //output a variable data to CPU board to verify long-time communication always@(posedge clk or negedge nRST) begin if(~nRST) begin count <= 25'h0; data_temp <= 8'h0; end else if(count == 25'h16e3200) begin count <= 25'h0; data_temp <= data_temp + 1'b1; end else count <= count + 1'b1; end //backplane communication FSM //1st always block,synchronously update currentstate with next state always@(posedge clk or negedge nRST) begin if(~nRST) CS <= Bus_Idle; else CS <= NS; end //2nd always block,combinational condition judgement always@(b_addr or CS or b_rd or b_wr) begin NS = CS; case(CS) Bus_Idle: begin if(b_addr == DO_base_addr) NS = Bus_RW; end Bus_RW: begin if((b_rd == 1'b1)&&(b_wr == 1'b0))//firstly write to DO,then read data from DO NS = Bus_Ready; end Bus_Ready: begin NS = Bus_Data; end Bus_Data: begin if(b_addr[5:0] == 6'h5) NS = Bus_Ready_UN; end Bus_Ready_UN: begin NS = Bus_Finish; end Bus_Finish: begin NS = Bus_Idle; end default: begin NS = Bus_Idle; end endcase end //3rd always block,synchronously output always@(posedge clk or negedge nRST) begin if(~nRST) begin ready <= 1'b1; read_flag <= 1'b1; data <= 8'h0; oe <= 4'b0101; dir <= 4'b1101; end else case(CS) Bus_Idle: begin oe <= 4'b0011; dir <= 4'b1101; ready <= 1'b1; end Bus_RW: begin oe <= 4'b0000; end Bus_Ready: begin ready <= 1'b0; end Bus_Data: begin if(b_addr[5:0] == 6'h0) b_trigger_temp[13:8] <= b_data[5:0]; else if(b_addr[5:0] == 6'h1) b_trigger_temp[7:0] <= b_data; else if(b_addr[5:0] == 6'h2) begin read_flag <= 1'b0; dir <= 4'b1100; b_trigger <= b_trigger_temp; end else if(b_addr[5:0] == 6'h3) data <= data_temp; else if(b_addr[5:0] == 6'h4) data <= data_temp; else data <= 8'hcc; end Bus_Ready_UN: begin read_flag <= 1'b1; ready <= 1'b1; end endcase end always@(posedge clk or negedge nRST) begin if(~nRST) begin led <= 14'h2aaa; end else begin led <={2'h0,CS, b_trigger_temp[7:0]}; // led <= b_trigger_temp; end end endmodule |
状态机的输入条件时序没有给出,很难去判断为何会状态异常,大多情况都是出现了你没有列出转移条件,从而导致的异常,就你列出的代码而言,个人感觉有两个问题,你可以作为参考:
1、NRST为低时,CS<=IDLE状态,同时 “oe <= 4'b0101”,但在状态输出中,当CS==IDLE 状态,oe <= 4'b0011,这两个输出是矛盾的,即NRST时,CS必然为IDLE ,也就是说在NRST为低时,oe可能有两个赋值。 2、data_temp的值可能溢出,不知道你关心这个不。希望对你有用
最佳答案
GMT+8, 2024-9-23 17:20 , Processed in 0.485187 second(s), Total 42, Slave 35 queries .
