扫一扫,分享给好友
新增加和更新下面的ASIC IP cores,需要的可以联系:
1. Synopsys Superspeed USB3.0 Host controller soft core (AHB interface) 2. Synopsys Superspeed USB3.0 Device controller soft core (AHB interface) 3. Synopsys Superspeed USB3.0 Hub controller softcore 4. ARM1176JZF-S CPU soft IP core (with VFP) 5. ARM Mail55 3D graphics soft IP core 6. ARM PL301 L2 Cache Controller IP core 7. MIPS4K CPU soft IP core 8. MIPS24KC CPU soft IP core 9. AMD 2D/vector graphics soft IP core (support OpenVG1.1 / Adobe Flash 7.0 ) 10. AMD 3D graphics soft IP core (support OpenGL ES2.0) 11. Imagine Technogies SGX520 3D graphics soft IP core (for med end products) 12. Imagine Technogies SGX535 3D graphics soft IP core (for high end products) 13. Imagine Technogies TV encoder soft IP core ( support 720P/1080i HD encoder) 14. Zoran CVD2 TV decoder soft IP core 15. Arasan SD2.0/SDIO2.0/MMC4.0 host controller soft IP core 16. Arasna SDIO2.0 device controller soft IP core 17. Arasan Nandflash controller soft IP core 18. Sillicon Image HDMI transimiter 1.1 controller soft IP core 19. TSMC 90G 10bit 250M ADC data converter hard IP core 20. TSMC 90G eFuse OTP hard IP core 21. TSMC 90LP eFuse OTP hard IP core 22. Charted 0.18um 1.8v/5.0v eMemory (OTP) hard IP core 24. Silltera 0.18um 1.8v/5.0v eMemory (OTP) hard IP core 25. Chipieda USB2.0 High speed device controller soft IP core 26. Chipieda USB2.0 High speed single-port host controller soft IP core 27. Chipieda USB2.0 High speed OTG controller soft IP core 28. Chipieda USB2.0 High speed multi-point host controller soft IP core 29. Chipieda USB2.0 Full speed OTG device controller soft IP core 30. Chipieda WLAN AFE (8bit, 22MHz/44MHz) hard IP core (TSMC65LP) 31. Cast 1T R8051XC2 8bit soft MCU core 32. USB1.0/USB2.0 controller and PHY 33. PCIe Controller/PHY 34. SATA controller and PHY 35. DDR2/DDR, DDR2/DDR3 controller and PHY 36. Mentor SATA host /Device controller core and PHY 37. H264/MPEG4 Codec 38. H264/MPEG4 Decoder 需要的可以联系: jasper1949@gmail.com |
124 浏览 0 评论
1800 浏览 0 评论
1323 浏览 0 评论
PCM2912APJTR设计的USB声卡播放声音有哒哒的声音的原因有哪些
941 浏览 0 评论
一个过零检测电路,但有部分电路没看明白,有大神可以详细解释一下吗
1153 浏览 1 评论
GMT+8, 2025-3-26 16:45 , Processed in 0.668102 second(s), Total 70, Slave 53 queries .
