扫一扫,分享给好友
% Particle filter example.
% Track a body falling through the atmosphere. % This system is taken from [Jul00], which was based on [Ath68]. rho0 = 2; % lb-sec^2/ft^4 g = 32.2; % ft/sec^2 k = 2e4; % ft R = 10^4; % measurement noise variance (ft^2) Q = diag([0 0 0]); % process noise covariance M = 10^5; % horizontal range of position sensor a = 10^5; % altitude of position sensor P = diag([1e6 4e6 10]); % initial estimation error covariance x = [3e5; -2e4; 1e-3]; % initial state xhat = [3e5; -2e4; 1e-3]; % initial state estimate N = 100; % number of particles % Initialize the particle filter. for i = 1 : N xhatplus(:,i) = x + sqrt(P) * [randn; randn; randn]; end T = 0.5; % measurement time step randn('state',sum(100*clock)); % random number generator seed tf = 30; % simulation length (seconds) dt = 0.04; % time step for integration (seconds) xArray = x; xhatArray = xhat; for t = T : T : tf fprintf('.'); % Simulate the system. for tau = dt : dt : T % Fourth order Runge Kutta ingegration dx1(1,1) = x(2); dx1(2,1) = rho0 * exp(-x(1)/k) * x(2)^2 / 2 * x(3) - g; dx1(3,1) = 0; dx1 = dx1 * dt; xtemp = x + dx1 / 2; dx2(1,1) = xtemp(2); dx2(2,1) = rho0 * exp(-xtemp(1)/k) * xtemp(2)^2 / 2 * xtemp(3) - g; dx2(3,1) = 0; dx2 = dx2 * dt; xtemp = x + dx2 / 2; dx3(1,1) = xtemp(2); dx3(2,1) = rho0 * exp(-xtemp(1)/k) * xtemp(2)^2 / 2 * xtemp(3) - g; dx3(3,1) = 0; dx3 = dx3 * dt; xtemp = x + dx3; dx4(1,1) = xtemp(2); dx4(2,1) = rho0 * exp(-xtemp(1)/k) * xtemp(2)^2 / 2 * xtemp(3) - g; dx4(3,1) = 0; dx4 = dx4 * dt; x = x + (dx1 + 2 * dx2 + 2 * dx3 + dx4) / 6; x = x + sqrt(dt * Q) * [randn; randn; randn] * dt; end % Simulate the noisy measurement. z = sqrt(M^2 + (x(1)-a)^2) + sqrt(R) * randn; % Simulate the continuous-time part of the particle filter (time update). xhatminus = xhatplus; for i = 1 : N for tau = dt : dt : T % Fourth order Runge Kutta ingegration xtemp = xhatminus(:,i); dx1(1,1) = xtemp(2); dx1(2,1) = rho0 * exp(-xtemp(1)/k) * xtemp(2)^2 / 2 * xtemp(3) - g; dx1(3,1) = 0; dx1 = dx1 * dt; xtemp = xhatminus(:,i) + dx1 / 2; dx2(1,1) = xtemp(2); dx2(2,1) = rho0 * exp(-xtemp(1)/k) * xtemp(2)^2 / 2 * xtemp(3) - g; dx2(3,1) = 0; dx2 = dx2 * dt; xtemp = xhatminus(:,i) + dx2 / 2; dx3(1,1) = xtemp(2); dx3(2,1) = rho0 * exp(-xtemp(1)/k) * xtemp(2)^2 / 2 * xtemp(3) - g; dx3(3,1) = 0; dx3 = dx3 * dt; xtemp = xhatminus(:,i) + dx3; dx4(1,1) = xtemp(2); dx4(2,1) = rho0 * exp(-xtemp(1)/k) * xtemp(2)^2 / 2 * xtemp(3) - g; dx4(3,1) = 0; dx4 = dx4 * dt; xhatminus(:,i) = xhatminus(:,i) + (dx1 + 2 * dx2 + 2 * dx3 + dx4) / 6; xhatminus(:,i) = xhatminus(:,i) + sqrt(dt * Q) * [randn; randn; randn] * dt; xhatminus(3,i) = max(0, xhatminus(3,i)); % the ballistic coefficient cannot be negative end zhat = sqrt(M^2 + (xhatminus(1,i)-a)^2); vhat(i) = z - zhat; end % Note that we need to scale all of the q(i) probabilities in a way % that does not change their relative magnitudes. % Otherwise all of the q(i) elements will be zero because of the % large value of the exponential. vhatscale = max(abs(vhat)) / 4; qsum = 0; for i = 1 : N q(i) = exp(-(vhat(i)/vhatscale)^2); qsum = qsum + q(i); end % Normalize the likelihood of each a priori estimate. for i = 1 : N q(i) = q(i) / qsum; end % Resample. for i = 1 : N u = rand; % uniform random number between 0 and 1 qtempsum = 0; for j = 1 : N qtempsum = qtempsum + q(j); if qtempsum >= u xhatplus(:,i) = xhatminus(:,j); % Use roughening to prevent sample impoverishment. E = max(xhatminus')' - min(xhatminus')'; sigma = 0.2 * E * N^(-1/length(x)); xhatplus(:,i) = xhatplus(:,i) + sigma .* [randn; randn; randn]; xhatplus(3,i) = max(0,xhatplus(3,i)); % the ballistic coefficient cannot be negative break; end end end % The particle filter estimate is the mean of the particles. xhat = 0; for i = 1 : N xhat = xhat + xhatplus(:,i); end xhat = xhat / N; % Save data for plotting. xArray = [xArray x]; xhatArray = [xhatArray xhat]; end close all; t = 0 : T : tf; figure; semilogy(t, abs(xArray(1,:) - xhatArray(1,:)), 'b'); hold; set(gca,'FontSize',12); set(gcf,'Color','White'); xlabel('Seconds'); ylabel('Altitude Estimation Error'); figure; semilogy(t, abs(xArray(2,:) - xhatArray(2,:)), 'b'); hold; set(gca,'FontSize',12); set(gcf,'Color','White'); xlabel('Seconds'); ylabel('Velocity Estimation Error'); figure; semilogy(t, abs(xArray(3,:) - xhatArray(3,:)), 'b'); hold; set(gca,'FontSize',12); set(gcf,'Color','White'); xlabel('Seconds'); ylabel('Ballistic Coefficient Estimation Error'); figure; plot(t, xArray(1,:)); set(gca,'FontSize',12); set(gcf,'Color','White'); xlabel('Seconds'); ylabel('True Position'); figure; plot(t, xArray(2,:)); title('Falling Body Simulation', 'FontSize', 12); set(gca,'FontSize',12); set(gcf,'Color','White'); xlabel('Seconds'); ylabel('True Velocity'); |
基本FPGA或者树莓派或者其它微处理器(尽量压缩成本且完成项目)DFB激光器稳频
1449 浏览 1 评论
2542 浏览 1 评论
助力AIoT应用:在米尔FPGA开发板上实现Tiny YOLO V4
1203 浏览 0 评论
3693 浏览 1 评论
3303 浏览 0 评论
2336 浏览 58 评论
6190 浏览 113 评论
GMT+8, 2025-2-2 16:15 , Processed in 0.398932 second(s), Total 36, Slave 31 queries .
