#include
#include #define DATAPORT P1 #define RS = P2^5 #define RW = P2^6 #define E = P2^7 unsigned char Busy_Check() { unsigned char LCD_Status; RS = 0; RW = 1; E = 1; delayMS(1); LCD_Status = P1; E = 0; return LCD_status; } void Write_LCD_Command(unsigned char cmd) { while(Busy_Check()&0x80); RS = 0; RW = 0; E = 0; P1 = cmd; E = 1; delayMS(1); E = 0; } viod Write_LCD_Data(unsigned char dat) { while(Busy_Check()&0x80 == 0x80); RS = 1; RW = 0; E = 0; P1 = dat; E = 1; delayMS(1); E = 0; } viod Initialize_LCD() { Write_LCD_Command(0x38); delayMS(1); Write_LCD_Command(0x01); delayMS(1) Write_LCD_Command(0x06); delayMS(1); Write_LCD_Command(0x0c); delayMS(1); } viod ShowString(unsigned char x, unsigned char y, unsigned char *str) { unsigned char i = 0; if(y == 0) Write_LCD_Command(0x80|x); if(y == 1) Write_LCD_Command(0xc0|x); for(i = 0; i < 16; i++) { Write_LCD_Data(str); } } main(viod) { unsigned char code Promt[]="HELLO WORLD! 2016-04-25"; Initalize_lcd(); ShowString(0,0,Prompt); ShowString(0,1,Prompt+16); while(1) } 编译时keil4提示错误错误代码 compiling lesson1.c... LESSON1.C(10): error C141: syntax error near '=' LESSON1.C(10): error C141: syntax error near '=' LESSON1.C(11): error C141: syntax error near '=' LESSON1.C(11): error C141: syntax error near '=' LESSON1.C(12): error C141: syntax error near '=' LESSON1.C(12): error C141: syntax error near '=' lesson1.c - 6 Error(s), 0 Warning(s). 请高手看看是哪里错了 |
3个回答
#define RS = P2^5
#define RW = P2^6 #define E = P2^7 这个有错误,你可以试试把这个改成位定义,即就是#define改为***it |
谢谢 已经改了 |
定义管脚怎么是宏定义,位***it定义试一试
《DNESP32S3使用指南-IDF版_V1.6》第三十章 DHT11数字温湿度传感器
522 浏览 0 评论
656 浏览 0 评论
【敏矽微ME32G070开发板免费体验】之原厂2812测试例程解析
978 浏览 0 评论
1042 浏览 2 评论
《DNESP32S3使用指南-IDF版_V1.6》第二十六章 INFRARED_RECEPTION实验
735 浏览 0 评论
12045 浏览 31 评论
GMT+8, 2024-12-27 13:57 , Processed in 0.398336 second(s), Total 40, Slave 35 queries .
