扫一扫,分享给好友
广播的数据长度是有限制的,不一定能带上所有的
可修改的部分参考: static uint8 advertData[] = { // Flags; this sets the device to use limited discoverable // mode (advertises for 30 seconds at a time) instead of general // discoverable mode (advertises indefinitely) 0x02, // length of this data GAP_ADTYPE_FLAGS, DEFAULT_DISCOVERABLE_MODE | GAP_ADTYPE_FLAGS_BREDR_NOT_SUPPORTED, // service UUID, to notify central devices what services are included // in this peripheral 0x03, // length of this data GAP_ADTYPE_16BIT_MORE, // some of the UUID's, but not all LO_UINT16( SIMPLEPROFILE_SERV_UUID ), HI_UINT16( SIMPLEPROFILE_SERV_UUID ), }; |
3487个成员聚集在这个小组
3354 浏览 1 评论
4000 浏览 0 评论
3503 浏览 0 评论
4083 浏览 1 评论
20760 浏览 11 评论
907浏览 2评论
1196浏览 2评论
1123浏览 1评论
1317浏览 1评论
467浏览 1评论
GMT+8, 2025-3-6 19:49 , Processed in 0.837500 second(s), Total 77, Slave 61 queries .
