扫一扫,分享给好友
帮忙看下怎么修改啊 ,我修改了一点,但是添加的屏还是显示不出字,而且仿真图上出现完郭雪培会出现一段乱码再循环,我也不明白为什么??
#include #define uchar unsigned char #define uint unsigned int #define SPEED 1 //移动数度快慢值 uchar col,disrow; uint word; uchar code HZ[]; uchar BUFF[12]; //buff[]为要显示的数字*2+2 void loadoneline(void); void sendoneline(void); /*******根据列指针,由双字节合并为单字节的子程序模块************/ uchar two_onebyte(uchar h1,uchar h2) { uchar temp,tempcol; if(col<8) tempcol=col; else tempcol=col-8; temp=(h1< temp=255-temp; return temp; } /****************************主函数***************************/ void main(void) { uchar i; col=0;word=0; while(1) { while(col<16)// 循环16次,点亮并移动一个汉字 { for(i=0;i { for(disrow=0;disrow<16;disrow++)//扫描16行 { loadoneline();//装载一线点阵数据 sendoneline();//发送一线点阵数据 P1_4=1; //消影。 E接在P2_4 ,=1; P1=0x10+disrow;// 点亮屏幕 P1=0x20+disrow; } } col++; //列指针递增 } col=0;word=word+32;// 一个汉字移动后,指向下一个汉字 if(word>=175)word=0;// 移动50个汉字后,重新开始 } } /**************装载一线点阵数据****************/ void loadoneline(void) { uchar s; for(s=0;s<6;s++) //s为要显示的数字+1 { BUFF[2*s]=HZ[word+32*s+2*disrow]; BUFF[2*s+1]=HZ[word+1+32*s+2*disrow]; } } /***************发送一线点阵数据*******************/ void sendoneline(void) { char s;uchar inc; if(col<8)inc=0;else inc=1; for(s=11+inc;s>=0+inc;s--) //s*2为要显示的数字+1 { SBUF=two_onebyte(BUFF while(!ti);TI=0; } } /***********************汉字点阵码*************************/ uchar code HZ[]= { 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //============================================================================= //************************************************************************** 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, /****************************************************************************/ 0x10,0x00,0x08,0x7C,0xFF,0x44,0x00,0x48,0x7E,0x48,0x42,0x50,0x7E,0x48,0x00,0x48, 0x7E,0x44,0x04,0x44,0x08,0x44,0x0F,0x68,0xF8,0x50,0x08,0x40,0x28,0x40,0x10,0x40,/*"郭",0*/ 0x3F,0xF8,0x01,0x00,0x7F,0xFE,0x41,0x02,0x9D,0x74,0x01,0x00,0x1D,0x70,0x00,0x00, 0x3F,0xF8,0x00,0x08,0x00,0x08,0x1F,0xF8,0x00,0x08,0x00,0x08,0x3F,0xF8,0x00,0x08,/*"雪",1*/ 0x10,0x40,0x10,0x20,0x11,0xFC,0x10,0x00,0x11,0x08,0xFC,0x90,0x10,0x00,0x13,0xFE, 0x10,0x00,0x10,0x00,0x11,0xFC,0x1D,0x04,0xE1,0x04,0x41,0x04,0x01,0xFC,0x01,0x04,/*"培",2*/ 0x04,0x40,0x0E,0x50,0x78,0x48,0x08,0x48,0x08,0x40,0xFF,0xFE,0x08,0x40,0x08,0x44, //============================================================================ };
找你更换的屏幕的手册
《DNESP32S3使用指南-IDF版_V1.6》第六十章 猫脸检测实验
604 浏览 2 评论
969 浏览 2 评论
684 浏览 0 评论
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-Pinctrl和GPIO子系统之ioctl介绍
637 浏览 0 评论
1340 浏览 1 评论
12684 浏览 31 评论
GMT+8, 2025-4-2 08:32 , Processed in 0.603173 second(s), Total 75, Slave 55 queries .
