扫一扫,分享给好友
Checking Misleading Tap connection
ERROR [DRC0039] Tap may not be connected with the bus Check Entire net. SEG00: SCHEMATIC1, PAGE1 (4.00, 7.50) ERROR [DRC0039] Tap may not be connected with the bus Check Entire net. SEG00: SCHEMATIC1, PAGE1 (8.70, 0.90) ERROR [DRC0039] Tap may not be connected with the bus Check Entire net. SEG01: SCHEMATIC1, PAGE1 (8.70, 1.50) ERROR [DRC0039] Tap may not be connected with the bus Check Entire net. SEG01: SCHEMATIC1, PAGE1 (4.10, 7.50) ERROR [DRC0039] Tap may not be connected with the bus Check Entire net. SEG02: SCHEMATIC1, PAGE1 (8.70, 2.10) ERROR [DRC0039] Tap may not be connected with the bus Check Entire net. SEG02: SCHEMATIC1, PAGE1 (4.20, 7.50) ERROR [DRC0039] Tap may not be connected with the bus Check Entire net. SEG03: SCHEMATIC1, PAGE1 (8.70, 2.70) ERROR [DRC0039] Tap may not be connected with the bus Check Entire net. SEG03: SCHEMATIC1, PAGE1 (4.40, 4.00) ERROR [DRC0039] Tap may not be connected with the bus Check Entire net. SEG04: SCHEMATIC1, PAGE1 (8.70, 3.30) ERROR [DRC0039] Tap may not be connected with the bus Check Entire net. SEG04: SCHEMATIC1, PAGE1 (4.30, 4.00) ERROR [DRC0039] Tap may not be connected with the bus Check Entire net. SEG05: SCHEMATIC1, PAGE1 (8.70, 3.90) ERROR [DRC0039] Tap may not be connected with the bus Check Entire net. SEG05: SCHEMATIC1, PAGE1 (4.20, 4.00) ERROR [DRC0039] Tap may not be connected with the bus Check Entire net. SEG06: SCHEMATIC1, PAGE1 (4.10, 4.00) ERROR [DRC0039] Tap may not be connected with the bus Check Entire net. SEG06: SCHEMATIC1, PAGE1 (8.70, 4.50) ERROR [DRC0039] Tap may not be connected with the bus Check Entire net. SEG07: SCHEMATIC1, PAGE1 (8.70, 5.10) ERROR [DRC0039] Tap may not be connected with the bus Check Entire net. SEG07: SCHEMATIC1, PAGE1 (4.00, 4.00) ERROR [DRC0039] Tap may not be connected with the bus Check Entire net. SEG08: SCHEMATIC1, PAGE1 (3.80, 4.00) ERROR [DRC0039] Tap may not be connected with the bus Check Entire net. SEG09: SCHEMATIC1, PAGE1 (3.70, 4.00) ERROR [DRC0039] Tap may not be connected with the bus Check Entire net. COM00: SCHEMATIC1, PAGE1 (3.50, 7.80) ERROR [DRC0039] Tap may not be connected with the bus Check Entire net. COM00: SCHEMATIC1, PAGE1 (8.50, 12.70) ERROR [DRC0039] Tap may not be connected with the bus Check Entire net. COM01: SCHEMATIC1, PAGE1 (3.60, 7.80) ERROR [DRC0039] Tap may not be connected with the bus Check Entire net. COM01: SCHEMATIC1, PAGE1 (8.50, 12.80) ERROR [DRC0039] Tap may not be connected with the bus Check Entire net. COM02: SCHEMATIC1, PAGE1 (8.50, 12.90) ERROR [DRC0039] Tap may not be connected with the bus Check Entire net. COM02: SCHEMATIC1, PAGE1 (3.70, 7.80) ERROR [DRC0039] Tap may not be connected with the bus Check Entire net. COM03: SCHEMATIC1, PAGE1 (8.50, 13.00) ERROR [DRC0039] Tap may not be connected with the bus Check Entire net. COM03: SCHEMATIC1, PAGE1 (3.80, 7.80) ERROR [DRC0039] Tap may not be connected with the bus Check Entire net. COM04: SCHEMATIC1, PAGE1 (8.50, 13.10) ERROR [DRC0039] Tap may not be connected with the bus Check Entire net. COM04: SCHEMATIC1, PAGE1 (3.90, 7.80) Check Bus width mismatch |
503 浏览 0 评论
求助一下关于51系列单片机的Timer0的计时问题,TH0、TL0+1的时间是怎么算的?
1756 浏览 1 评论
【RA-Eco-RA4E2-64PIN-V1.0开发板试用】开箱+Keil环境搭建+点灯+点亮OLED
1183 浏览 0 评论
【敏矽微ME32G070开发板免费体验】使用coremark测试敏矽微ME32G070 跑分
1053 浏览 0 评论
【敏矽微ME32G070开发板免费体验】开箱+点灯+点亮OLED
1287 浏览 2 评论
12022 浏览 31 评论
GMT+8, 2024-12-23 20:55 , Processed in 0.401256 second(s), Total 36, Slave 31 queries .
