`U-Boot 2014.04-rc2 (Aug 04 2015 - 15:32:20) I2C: ready DRAM: 512 MiB MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1 Net: cpsw Hit any key to stop autoboot: 0 reading logo.bmp 1152054 bytes read in 75 ms (14.6 MiB/s) mmc1(part 0) is current device SD/MMC found on device 1 reading uEnv.txt 105 bytes read in 4 ms (25.4 KiB/s) Loaded environment from uEnv.txt Importing environment from mmc ... reading uImage 4156576 bytes read in 257 ms (15.4 MiB/s) reading com335x-emmc.dtb 32925 bytes read in 8 ms (3.9 MiB/s) ## Booting kernel from Legacy Image at 81000000 ... Image Name: Linux-3.14.43-g875c69b Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 4156512 Bytes = 4 MiB Load Address: 80008000 Entry Point: 80008000 Verifying Checksum ... OK ## Flattened Device Tree blob at 82000000 Booting using the fdt blob at 0x82000000 Loading Kernel Image ... OK Loading Device Tree to 9fb4a000, end 9fb5509c ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 3.14.43-g875c69b (Vic@EAC) (gcc version 4.7.3 20130 226 (prerelease) (crosstool-NG linaro-1.13.1-4.7-2013.03-20130313 - Linaro GCC 2 013.03) ) #25 Mon Aug 3 15:50:42 CST 2015 [ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructio n cache [ 0.000000] Machine model: TI AM335x com335x [ 0.000000] cma: CMA: reserved 24 MiB at 9e000000 [ 0.000000] Memory policy: Data cache writeback [ 0.000000] CPU: All CPU(s) started in SVC mode. [ 0.000000] AM335X ES2.1 (neon ) [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pag es: 129792 [ 0.000000] Kernel command line: console=ttyO0,115200n8 tty0 noinitrd root=/d ev/mmcblk0p2 rw rootfstype=ext4 rootwait lcdtype=AUO_AT070TN94 consoleblank=0 [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] Memory: 485448K/523264K available (5507K kernel code, 271K rwdata , 2260K rodata, 252K init, 227K bss, 37816K reserved, 0K highmem) [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB) [ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc079e0c4 (7769 kB) [ 0.000000] .init : 0xc079f000 - 0xc07de3b4 ( 253 kB) [ 0.000000] .data : 0xc07e0000 - 0xc0823ce0 ( 272 kB) [ 0.000000] .bss : 0xc0823ce0 - 0xc085cb80 ( 228 kB) [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrup ts [ 0.000000] Total of 128 interrupts on 1 active controller [ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz [ 0.000016] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 17895 6969942ns [ 0.000036] OMAP clocksource: timer1 at 24000000 Hz [ 0.000308] Console: colour dummy device 80x30 [ 0.000336] Calibrating delay loop... 795.44 BogoMIPS (lpj=3977216) [ 0.089424] pid_max: default: 32768 minimum: 301 [ 0.089527] Security Framework initialized [ 0.089585] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.089595] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.096549] CPU: Testing write buffer coherency: ok [ 0.096958] Setting up static identity map for 0x80566360 - 0x805663b8 [ 0.097947] devtmpfs: initialized [ 0.099995] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3 [ 0.106979] omap_hwmod: tptc0 using broken dt data from edma [ 0.107061] omap_hwmod: tptc1 using broken dt data from edma [ 0.107133] omap_hwmod: tptc2 using broken dt data from edma [ 0.111304] omap_hwmod: debugss: _wait_target_disable failed [ 0.166683] pinctrl core: initialized pinctrl subsystem [ 0.167754] regulator-dummy: no parameters [ 0.170299] NET: Registered protocol family 16 [ 0.172368] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.174980] cpuidle: using governor ladder [ 0.174996] cpuidle: using governor menu [ 0.181466] syscon 44e10000.control_module: regmap [mem 0x44e10000-0x44e107fb ] registered [ 0.182925] platform 49000000.edma: alias fck already exists [ 0.182948] platform 49000000.edma: alias fck already exists [ 0.182963] platform 49000000.edma: alias fck already exists [ 0.184109] OMAP GPIO hardware version 0.1 [ 0.199319] No ATAGs? [ 0.199340] hw-breakpoint: debug architecture 0x4 unsupported. [ 0.224863] bio: create slab <bio-0> at 0 [ 0.241055] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver [ 0.242096] vmmcsd_fixed: 3300 mV [ 0.245251] vgaarb: loaded [ 0.245790] i2c-core: driver [palmas] using legacy suspend method [ 0.245800] i2c-core: driver [palmas] using legacy resume method [ 0.246531] SCSI subsystem initialized [ 0.248036] u***core: registered new interface driver u***fs [ 0.248224] u***core: registered new interface driver hub [ 0.248419] u***core: registered new device driver u*** [ 0.249457] omap_i2c 44e0b000.i2c: could not find pctldev for node [url=]/pinmux@44[/url] e10800/pinmux_i2c0_pins, deferring probe [ 0.249486] platform 44e0b000.i2c: Driver omap_i2c requests probe deferral [ 0.249897] pps_core: LinuxPPS API ver. 1 registered [ 0.249909] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome tti <giometti@linux.it> [ 0.250045] PTP clock support registered [ 0.252050] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400 [ 0.252969] Advanced Linux Sound Architecture Driver Initialized. [ 0.254692] Switched to clocksource timer1 [ 0.274119] NET: Registered protocol family 2 [ 0.275154] TCP established hash table entries: 4096 (order: 2, 16384 bytes) [ 0.275209] TCP bind hash table entries: 4096 (order: 2, 16384 bytes) [ 0.275255] TCP: Hash tables configured (established 4096 bind 4096) [ 0.275331] TCP: reno registered [ 0.275343] UDP hash table entries: 256 (order: 0, 4096 bytes) [ 0.275361] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) [ 0.275545] NET: Registered protocol family 1 [ 0.275938] RPC: Registered named UNIX socket transport module. [ 0.275951] RPC: Registered udp transport module. [ 0.275957] RPC: Registered tcp transport module. [ 0.275964] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.277144] hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver, 5 counter s available [ 0.279942] futex hash table entries: 256 (order: -1, 3072 bytes) [ 0.443192] VFS: Disk quotas dquot_6.5.2 [ 0.443261] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.443787] NFS: Registering the id_resolver key type [ 0.443868] Key type id_resolver registered [ 0.443878] Key type id_legacy registered [ 0.443933] msgmni has been set to 996 [ 0.445486] NET: Registered protocol family 38 [ 0.445532] io scheduler noop registered [ 0.445540] io scheduler deadline registered [ 0.445562] io scheduler cfq registered (default) [ 0.447325] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568 [ 0.453794] omap_uart 44e09000.serial: no wakeirq for uart0 [ 0.453949] 44e09000.serial: ttyO0 at MMIO 0x44e09000 (irq = 88, base_baud = 3000000) is a OMAP UART0 [ 1.080853] console [ttyO0] enabled [ 1.085219] omap_uart 48022000.serial: no wakeirq for uart0 [ 1.091168] 48022000.serial: ttyO1 at MMIO 0x48022000 (irq = 89, base_baud = 3000000) is a OMAP UART1 [ 1.101492] omap_uart 48024000.serial: no wakeirq for uart0 [ 1.107509] 48024000.serial: ttyO2 at MMIO 0x48024000 (irq = 90, base_baud = 3000000) is a OMAP UART2 [ 1.117733] omap_uart 481a6000.serial: no wakeirq for uart0 [ 1.123669] 481a6000.serial: ttyO3 at MMIO 0x481a6000 (irq = 60, base_baud = 3000000) is a OMAP UART3 [ 1.133950] omap_uart 481a8000.serial: no wakeirq for uart0 [ 1.139965] 481a8000.serial: ttyO4 at MMIO 0x481a8000 (irq = 61, base_baud = 3000000) is a OMAP UART4 [ 1.151052] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20 [ 1.158428] [drm] Initialized drm 1.1.0 20060810 [ 1.174183] brd: module loaded [ 1.182990] loop: module loaded [ 1.186950] (hci_tty): inside hci_tty_init [ 1.191683] (hci_tty): allocated 249, 0 [ 1.201460] CAN device driver interface [ 1.206986] c_can_platform 481cc000.can: c_can_platform device registered (re gs=fa1cc000, irq=68) [ 1.218275] u***core: registered new interface driver asix [ 1.224156] u***core: registered new interface driver ax88179_178a [ 1.230733] u***core: registered new interface driver cdc_ether [ 1.237050] u***core: registered new interface driver smsc95xx [ 1.243242] u***core: registered new interface driver net1080 [ 1.249324] u***core: registered new interface driver cdc_subset [ 1.255695] u***core: registered new interface driver zaurus [ 1.261781] u***core: registered new interface driver cdc_ncm [ 1.268295] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.275160] ehci-pci: EHCI PCI platform driver [ 1.280015] ehci-omap: OMAP-EHCI Host Controller driver [ 1.286018] u***core: registered new interface driver cdc_wdm [ 1.292157] u***core: registered new interface driver u***-storage [ 1.300839] 47401300.u***-phy supply vcc not found, using dummy regulator [ 1.310618] mu***-hdrc mu***-hdrc.0.auto: Failed to request rx1. [ 1.316918] mu***-hdrc mu***-hdrc.0.auto: mu***_init_controller failed with stat us -517 [ 1.325105] platform mu***-hdrc.0.auto: Driver mu***-hdrc requests probe deferr al [ 1.333544] 47401b00.u***-phy supply vcc not found, using dummy regulator [ 1.343174] mu***-hdrc mu***-hdrc.1.auto: Failed to request rx1. [ 1.349449] mu***-hdrc mu***-hdrc.1.auto: mu***_init_controller failed with stat us -517 [ 1.357626] platform mu***-hdrc.1.auto: Driver mu***-hdrc requests probe deferr al [ 1.379963] mousedev: PS/2 mouse device common for all mice [ 1.387554] TI-am335x-tsc TI-am335x-tsc: ti,charge-delay not specified [ 1.394955] input: ti-tsc as /devices/ocp/44e0d000.tscadc/TI-am335x-tsc/input /input0 [ 1.404924] i2c-core: driver [rtc-ds1307] using legacy suspend method [ 1.411669] i2c-core: driver [rtc-ds1307] using legacy resume method [ 1.419221] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0 [ 1.427589] i2c /dev entries driver [ 1.431398] Driver for 1-wire Dallas network protocol. [ 1.438385] ISL88013 of_get_gpio:111 [ 1.485247] 481d8000.mmc supply vmmc not found, using dummy regulator [ 1.495623] omap_hsmmc 481d8000.mmc: could not set regulator OCR (-22) [ 1.536394] ledtrig-cpu: registered to indicate activity on CPUs [ 1.543026] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2 [ 1.550611] omap-sham 53100000.sham: hw accel on OMAP rev 4.3 [ 1.558187] u***core: registered new interface driver u***hid [ 1.564019] u***hid: USB HID core driver [ 1.568398] platform 44d00000.wkup_m3: Driver wkup_m3 requests probe deferral [ 1.580239] davinci_evm sound: ASoC: CODEC (null) not registered [ 1.586707] davinci_evm sound: snd_soc_register_card failed (-517) [ 1.593192] platform sound: Driver davinci_evm requests probe deferral [ 1.601620] oprofile: using arm/armv7 [ 1.605878] TCP: cubic registered [ 1.609345] Initializing XFRM netlink socket [ 1.613827] NET: Registered protocol family 17 [ 1.618575] NET: Registered protocol family 15 [ 1.623233] can: controller area network core (rev 20120528 abi 9) [ 1.629786] NET: Registered protocol family 29 [ 1.634468] can: raw protocol (rev 20120528) [ 1.639008] can: broadcast manager protocol (rev 20120528 t) [ 1.644969] can: netlink gateway (rev 20130117) max_hops=1 [ 1.650871] Key type dns_resolver registered [ 1.656195] cpu cpu0: of_pm_voltdm_notifier_register: Failed to get cpu0 regu lator/voltdm: -517 [ 1.665353] cpu cpu0: cpu0 clock notifier not ready, retry [ 1.671184] platform cpufreq-cpu0.0: Driver cpufreq-cpu0 requests probe defer ral [ 1.679707] PM: bootloader does not support rtc-only! [ 1.685103] ThumbEE CPU extension supported. [ 1.689599] Registering SWP/SWPB emulation handler [ 1.695829] regulator-dummy: disabling [ 1.700537] Error: Driver 'tfp410' is already registered, aborting... [ 1.709855] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 1.716816] [drm] No driver support for vblank timestamp query. [ 1.768110] Console: switching to colour frame buffer device 100x30 [ 1.777919] tilcdc 4830e000.lcdc: fb0: frame buffer device [ 1.783749] tilcdc 4830e000.lcdc: registered panic notifier [ 1.789622] [drm] Initialized tilcdc 1.0.0 20121205 on minor 0 [ 1.799931] DCDC1: at 1500 mV [ 1.804408] vdd_mpu: 925 <--> 1325 mV at 1275 mV [ 1.809402] mmc0: host does not support reading read-only switch. assuming wr ite-enable. [ 1.819019] vdd_core: 925 <--> 1150 mV at 1125 mV [ 1.824134] mmc0: new high speed SDHC card at address 59b4 [ 1.831097] mmcblk0: mmc0:59b4 00000 7.34 GiB [ 1.835957] LDO1: at 1800 mV [ 1.840709] mmcblk0: p1 p2 [ 1.844060] LDO2: at 3300 mV [ 1.848913] LDO3: at 1800 mV [ 1.856284] LDO4: at 3300 mV [ 1.860476] tps65217 0-0024: TPS65217 ID 0xe version 1.2 [ 1.867298] rtc-ds1307 0-0068: SET TIME! [ 1.872516] rtc-ds1307 0-0068: rtc core: registered ds1339 as rtc1 [ 1.879047] omap_hsmmc 481d8000.mmc: exceeding card's volts [ 1.888792] 0-001b supply IOVDD not found, using dummy regulator [ 1.895234] 0-001b supply DVDD not found, using dummy regulator [ 1.901473] 0-001b supply AVDD not found, using dummy regulator [ 1.907758] 0-001b supply DRVDD not found, using dummy regulator [ 1.914762] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 64 bytes/write [ 1.922083] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz [ 1.931981] mu***-hdrc mu***-hdrc.0.auto: MUSB HDRC host driver [ 1.938579] mu***-hdrc mu***-hdrc.0.auto: new USB bus registered, assigned bus number 1 [ 1.947194] u*** u***1: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.954324] u*** u***1: New USB device strings: Mfr=3, Product=2, SerialNumber= 1 [ 1.961908] u*** u***1: Product: MUSB HDRC host driver [ 1.967116] u*** u***1: Manufacturer: Linux 3.14.43-g875c69b mu***-hcd [ 1.973674] u*** u***1: SerialNumber: mu***-hdrc.0.auto [ 1.979992] hub 1-0:1.0: USB hub found [ 1.984011] hub 1-0:1.0: 1 port detected [ 1.992536] mu***-hdrc mu***-hdrc.1.auto: MUSB HDRC host driver [ 1.999172] mu***-hdrc mu***-hdrc.1.auto: new USB bus registered, assigned bus number 2 [ 2.007658] u*** u***2: New USB device found, idVendor=1d6b, idProduct=0002 [ 2.014809] u*** u***2: New USB device strings: Mfr=3, Product=2, SerialNumber= 1 [ 2.022367] u*** u***2: Product: MUSB HDRC host driver [ 2.027574] u*** u***2: Manufacturer: Linux 3.14.43-g875c69b mu***-hcd [ 2.034130] u*** u***2: SerialNumber: mu***-hdrc.1.auto [ 2.040345] hub 2-0:1.0: USB hub found ` |
2 个讨论
【盈鹏飞RK3399安卓主板 XPC-3399Pro免费试用】+烧写出厂固件
10344 浏览 0 评论
【盈鹏飞EVB-T335开发板试用体验】debian系统烧写
3392 浏览 1 评论
【盈鹏飞I.MX6UL工控开发板试用体验】linux can 测试
3243 浏览 0 评论
338浏览 0评论
GMT+8, 2025-1-11 15:39 , Processed in 0.419721 second(s), Total 39, Slave 32 queries .
