扫一扫,分享给好友
cc2541开发板存储不够,怎么拓展? 我在cc2541 256k的开发板上有最大十几k的数据需要,所以首先想到用osal_snv_X系列的函数进行读写,但是在翻阅代码时,发现一共可用的nvram页才2页,因此这是 不够的,我的问题是,为什么只有2页充当nvram,能否向系统多要些页面来充当nvram,如果可以,该如何修改代码 |
Performing Flash Erase From Flash Memory Note that while executing program code from within flash memory, when a flash erase or write operation is initiated the CPU stalls, and program execution resumes from the next instruction when the flash controller has completed the operation. The following code example of how to erase one flash page in the CC2530 is given for use with the IAR compiler: #include unsigned char erase_page_num = 3; /* page number to erase, here: flash page #3 */ /* Erase one flash page */ EA = 0; /* disable interrupts */ while (FCTL & 0x80); /* poll FCTL.BUSY and wait until flash controller is ready */ FADDRH = erase_page_num << 1; /* select the flash page via FADDRH[7:1] bits */ FCTL |= 0x01; /* set FCTL.ERASE bit to start page erase */ while (FCTL & 0x80); /* optional: wait until flash write has completed (~20 ms) */ EA = 1; /* enable interrupts */ 6.3.2 Different Flash Page Size on CC2533 The flash page size has been reduced from 2 KB (2048 bytes) on CC2530, CC2531, CC2540, and CC2541 to 1 KB (1024 bytes) on CC2533. When performing page-erase operations on the flash memory, the page to be erased is addressed with the register bits FADDRH[6:0] on CC2533 as opposed to FADDRH[7:1] on CC2530, CC2531, CC2540, and CC2541. The page-lock bits are still placed in the upper 16 bytes of the last accessible flash page.这个是在其他帖子看到的,可以吗 |
fdvcxhtg 发表于 2016-3-28 13:46 哦,我试试,谢谢 ![]() |
3533个成员聚集在这个小组
3409 浏览 1 评论
4086 浏览 0 评论
3553 浏览 0 评论
4150 浏览 1 评论
20835 浏览 11 评论
987浏览 2评论
1787浏览 2评论
1226浏览 1评论
1446浏览 1评论
549浏览 1评论
GMT+8, 2025-4-15 05:29 , Processed in 0.830076 second(s), Total 44, Slave 39 queries .
