扫一扫,分享给好友
是不是你取得名字刚好是VHDL中的关键字了,你改一下,如ads_8bit
最佳答案
改了,之后就是这样
# Reading D:/altera/13.0sp1/modelsim_ase/tcl/vsim/pref.tcl # do abs_run_msim_rtl_vhdl.do # if {[file exists rtl_work]} { # vdel -lib rtl_work -all # } # vlib rtl_work # vmap work rtl_work # Copying D:altera13.0sp1modelsim_asewin32aloem/../modelsim.ini to modelsim.ini # Modifying modelsim.ini # ** Warning: Copied D:altera13.0sp1modelsim_asewin32aloem/../modelsim.ini to modelsim.ini. # Updated modelsim.ini. # # vcom -93 -work work {C:/Users/zjg/Desktop/FPGA/write_command_reply_module.vhd} # Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov 2 2012 # -- Loading package STANDARD # -- Loading package TEXTIO # -- Loading package std_logic_1164 # -- Loading package std_logic_arith # -- Loading package STD_LOGIC_UNSIGNED # -- Compiling entity write_command_reply_module # -- Compiling architecture write_command_reply_module_arc of write_command_reply_module # vcom -93 -work work {C:/Users/zjg/Desktop/FPGA/undefine_command_reply_module.vhd} # Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov 2 2012 # -- Loading package STANDARD # -- Loading package TEXTIO # -- Loading package std_logic_1164 # -- Loading package std_logic_arith # -- Loading package STD_LOGIC_UNSIGNED # -- Compiling entity undefine_command_reply_module # -- Compiling architecture undefine_command_reply_module_arc of undefine_command_reply_module # vcom -93 -work work {C:/Users/zjg/Desktop/FPGA/slave_process_module.vhd} # Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov 2 2012 # -- Loading package STANDARD # -- Loading package TEXTIO # -- Loading package std_logic_1164 # -- Loading package std_logic_arith # -- Loading package STD_LOGIC_UNSIGNED # -- Compiling entity slave_process_module # -- Compiling architecture slave_process_module_arc of slave_process_module # vcom -93 -work work {C:/Users/zjg/Desktop/FPGA/sampleclk.vhd} # Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov 2 2012 # -- Loading package STANDARD # -- Loading package TEXTIO # -- Loading package std_logic_1164 # -- Loading package std_logic_arith # -- Loading package STD_LOGIC_UNSIGNED # -- Compiling entity sampleclk # -- Compiling architecture behav of sampleclk # vcom -93 -work work {C:/Users/zjg/Desktop/FPGA/read_write_command_reply_module.vhd} # Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov 2 2012 # -- Loading package STANDARD # -- Loading package TEXTIO # -- Loading package std_logic_1164 # -- Loading package std_logic_arith # -- Loading package STD_LOGIC_UNSIGNED # -- Compiling entity read_write_command_reply_module # -- Compiling architecture read_write_command_reply_module_arc of read_write_command_reply_module # vcom -93 -work work {C:/Users/zjg/Desktop/FPGA/read_command_reply_module.vhd} # Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov 2 2012 # -- Loading package STANDARD # -- Loading package TEXTIO # -- Loading package std_logic_1164 # -- Loading package std_logic_arith # -- Loading package STD_LOGIC_UNSIGNED # -- Compiling entity read_command_reply_module # -- Compiling architecture read_command_reply_module_arc of read_command_reply_module # vcom -93 -work work {C:/Users/zjg/Desktop/FPGA/lsor6.vhd} # Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov 2 2012 # -- Loading package STANDARD # -- Loading package TEXTIO # -- Loading package std_logic_1164 # -- Loading package std_logic_arith # -- Loading package STD_LOGIC_UNSIGNED # -- Compiling entity lsor6 # -- Compiling architecture lsor6_arc of lsor6 # vcom -93 -work work {C:/Users/zjg/Desktop/FPGA/lsor3.vhd} # Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov 2 2012 # -- Loading package STANDARD # -- Loading package TEXTIO # -- Loading package std_logic_1164 # -- Loading package std_logic_arith # -- Loading package STD_LOGIC_UNSIGNED # -- Compiling entity lsor3 # -- Compiling architecture lsor3_arc of lsor3 # vcom -93 -work work {C:/Users/zjg/Desktop/FPGA/lsor2.vhd} # Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov 2 2012 # -- Loading package STANDARD # -- Loading package TEXTIO # -- Loading package std_logic_1164 # -- Loading package std_logic_arith # -- Loading package STD_LOGIC_UNSIGNED # -- Compiling entity lsor2 # -- Compiling architecture lsor2_arc of lsor2 # vcom -93 -work work {C:/Users/zjg/Desktop/FPGA/high_priority_supervisor.vhd} # Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov 2 2012 # -- Loading package STANDARD # -- Loading package TEXTIO # -- Loading package std_logic_1164 # -- Loading package std_logic_arith # -- Loading package STD_LOGIC_UNSIGNED # -- Compiling entity high_priority_supervisor # -- Compiling architecture BEHAIVER of high_priority_supervisor # vcom -93 -work work {C:/Users/zjg/Desktop/FPGA/gpmc_tri_buf.vhd} # Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov 2 2012 # -- Loading package STANDARD # -- Loading package TEXTIO # -- Loading package std_logic_1164 # -- Loading package std_logic_arith # -- Loading package STD_LOGIC_UNSIGNED # -- Compiling entity gpmc_tri_buf # -- Compiling architecture behav of gpmc_tri_buf # vcom -93 -work work {C:/Users/zjg/Desktop/FPGA/framing_module.vhd} # Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov 2 2012 # -- Loading package STANDARD # -- Loading package TEXTIO # -- Loading package std_logic_1164 # -- Loading package std_logic_arith # -- Loading package STD_LOGIC_UNSIGNED # -- Compiling entity framing_module # -- Compiling architecture framing_module_arc of framing_module # vcom -93 -work work {C:/Users/zjg/Desktop/FPGA/fram_send_module1.vhd} # Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov 2 2012 # -- Loading package STANDARD # -- Loading package TEXTIO # -- Loading package std_logic_1164 # -- Loading package std_logic_arith # -- Loading package STD_LOGIC_UNSIGNED # -- Compiling entity fram_send_module1 # -- Compiling architecture fram_send_module1_arc of fram_send_module1 # vcom -93 -work work {C:/Users/zjg/Desktop/FPGA/fram_recive_watchdog.vhd} # Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov 2 2012 # -- Loading package STANDARD # -- Loading package TEXTIO # -- Loading package std_logic_1164 # -- Loading package std_logic_arith # -- Loading package STD_LOGIC_UNSIGNED # -- Compiling entity fram_recive_watchdog # -- Compiling architecture BEHAIVER of fram_recive_watchdog # vcom -93 -work work {C:/Users/zjg/Desktop/FPGA/fram_recive.vhd} # Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov 2 2012 # -- Loading package STANDARD # -- Loading package TEXTIO # -- Loading package std_logic_1164 # -- Loading package std_logic_arith # -- Loading package STD_LOGIC_UNSIGNED # -- Compiling entity fram_recive # -- Compiling architecture fram_recive_arc of fram_recive # vcom -93 -work work {C:/Users/zjg/Desktop/FPGA/fram_analysis.vhd} # Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov 2 2012 # -- Loading package STANDARD # -- Loading package TEXTIO # -- Loading package std_logic_1164 # -- Loading package std_logic_arith # -- Loading package STD_LOGIC_UNSIGNED # -- Compiling entity fram_analysis # -- Compiling architecture BEHAIVER of fram_analysis # vcom -93 -work work {C:/Users/zjg/Desktop/FPGA/error_process_module.vhd} # Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov 2 2012 # -- Loading package STANDARD # -- Loading package TEXTIO # -- Loading package std_logic_1164 # -- Loading package std_logic_arith # -- Loading package STD_LOGIC_UNSIGNED # -- Compiling entity error_process_module # -- Compiling architecture error_process_module_arc of error_process_module # vcom -93 -work work {C:/Users/zjg/Desktop/FPGA/device_scan_command_reply_module.vhd} # Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov 2 2012 # -- Loading package STANDARD # -- Loading package TEXTIO # -- Loading package std_logic_1164 # -- Loading package std_logic_arith # -- Loading package STD_LOGIC_UNSIGNED # -- Compiling entity device_scan_command_reply_module # -- Compiling architecture device_scan_command_reply_module_arc of device_scan_command_reply_module # vcom -93 -work work {C:/Users/zjg/Desktop/FPGA/byte_send.vhd} # Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov 2 2012 # -- Loading package STANDARD # -- Loading package TEXTIO # -- Loading package std_logic_1164 # -- Loading package std_logic_arith # -- Loading package STD_LOGIC_UNSIGNED # -- Compiling entity byte_send # -- Compiling architecture byte_send_arc of byte_send # vcom -93 -work work {C:/Users/zjg/Desktop/FPGA/byte_recive.vhd} # Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov 2 2012 # -- Loading package STANDARD # -- Loading package TEXTIO # -- Loading package std_logic_1164 # -- Loading package std_logic_arith # -- Loading package STD_LOGIC_UNSIGNED # -- Compiling entity byte_recive # -- Compiling architecture byte_recive_arc of byte_recive # vcom -93 -work work {C:/Users/zjg/Desktop/FPGA/baud_gen.vhd} # Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov 2 2012 # -- Loading package STANDARD # -- Loading package TEXTIO # -- Loading package std_logic_1164 # -- Loading package std_logic_arith # -- Loading package STD_LOGIC_UNSIGNED # -- Compiling entity baud_gen # -- Compiling architecture BEHAIVER of baud_gen # vcom -93 -work work {C:/Users/zjg/Desktop/FPGA/altdpram5.vhd} # Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov 2 2012 # -- Loading package STANDARD # -- Loading package TEXTIO # -- Loading package std_logic_1164 # -- Compiling entity altdpram5 # -- Compiling architecture SYN of altdpram5 # vcom -93 -work work {C:/Users/zjg/Desktop/FPGA/altdpram0.vhd} # Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov 2 2012 # -- Loading package STANDARD # -- Loading package TEXTIO # -- Loading package std_logic_1164 # -- Compiling entity altdpram0 # -- Compiling architecture SYN of altdpram0 # vcom -93 -work work {C:/Users/zjg/Desktop/FPGA/Tamagawa_ABS_module.vhd} # Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov 2 2012 # -- Loading package STANDARD # -- Loading package TEXTIO # -- Loading package std_logic_1164 # -- Loading package std_logic_arith # -- Loading package STD_LOGIC_UNSIGNED # -- Compiling entity Tamagawa_ABS_module # -- Compiling architecture behav of Tamagawa_ABS_module # vcom -93 -work work {C:/Users/zjg/Desktop/FPGA/latchdata.vhd} # Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov 2 2012 # -- Loading package STANDARD # -- Loading package TEXTIO # -- Loading package std_logic_1164 # -- Loading package std_logic_arith # -- Loading package STD_LOGIC_UNSIGNED # -- Compiling entity latchdata # -- Compiling architecture behav of latchdata # vcom -93 -work work {C:/Users/zjg/Desktop/FPGA/input_data_module.vhd} # Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov 2 2012 # -- Loading package STANDARD # -- Loading package TEXTIO # -- Loading package std_logic_1164 # -- Loading package std_logic_arith # -- Loading package STD_LOGIC_UNSIGNED # -- Compiling entity input_data_module # -- Compiling architecture Behavioral of input_data_module # vcom -93 -work work {C:/Users/zjg/Desktop/FPGA/reset_gen.vhd} # Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov 2 2012 # -- Loading package STANDARD # -- Loading package TEXTIO # -- Loading package std_logic_1164 # -- Loading package std_logic_arith # -- Loading package STD_LOGIC_UNSIGNED # -- Compiling entity reset_gen # -- Compiling architecture behav of reset_gen # vcom -93 -work work {C:/Users/zjg/Desktop/FPGA/lpm_constant0.vhd} # Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov 2 2012 # -- Loading package STANDARD # -- Loading package TEXTIO # -- Loading package std_logic_1164 # -- Compiling entity lpm_constant0 # -- Compiling architecture SYN of lpm_constant0 # vcom -93 -work work {C:/Users/zjg/Desktop/FPGA/lpm_constant1.vhd} # Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov 2 2012 # -- Loading package STANDARD # -- Loading package TEXTIO # -- Loading package std_logic_1164 # -- Compiling entity lpm_constant1 # -- Compiling architecture SYN of lpm_constant1 # vcom -93 -work work {C:/Users/zjg/Desktop/FPGA/altpll0.vhd} # Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov 2 2012 # -- Loading package STANDARD # -- Loading package TEXTIO # -- Loading package std_logic_1164 # -- Compiling entity altpll0 # -- Compiling architecture SYN of altpll0 # vcom -93 -work work {C:/Users/zjg/Desktop/FPGA/ABS_config.vhd} # Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov 2 2012 # -- Loading package STANDARD # -- Loading package TEXTIO # -- Loading package std_logic_1164 # -- Loading package std_logic_arith # -- Loading package STD_LOGIC_UNSIGNED # -- Compiling entity ABS_config # -- Compiling architecture behav of ABS_config # vcom -93 -work work {C:/Users/zjg/Desktop/FPGA/lpm_constant4.vhd} # Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov 2 2012 # -- Loading package STANDARD # -- Loading package TEXTIO # -- Loading package std_logic_1164 # -- Compiling entity lpm_constant4 # -- Compiling architecture SYN of lpm_constant4 # vcom -93 -work work {C:/Users/zjg/Desktop/FPGA/LPM_CONSTAN22.vhd} # Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov 2 2012 # -- Loading package STANDARD # -- Loading package TEXTIO # -- Loading package std_logic_1164 # -- Compiling entity LPM_CONSTAN22 # -- Compiling architecture SYN of lpm_constan22 # vcom -93 -work work {C:/Users/zjg/Desktop/FPGA/input_data_module1.vhd} # Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov 2 2012 # -- Loading package STANDARD # -- Loading package TEXTIO # -- Loading package std_logic_1164 # -- Loading package std_logic_arith # -- Loading package STD_LOGIC_UNSIGNED # -- Compiling entity input_data_module1 # -- Compiling architecture Behavioral of input_data_module1 # vcom -93 -work work {C:/Users/zjg/Desktop/FPGA/output_files/lpm_constant0001.vhd} # Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov 2 2012 # -- Loading package STANDARD # -- Loading package TEXTIO # -- Loading package std_logic_1164 # -- Compiling entity lpm_constant0001 # -- Compiling architecture SYN of lpm_constant0001 # vcom -93 -work work {C:/Users/zjg/Desktop/FPGA/output_files/lpm_constant0002.vhd} # Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov 2 2012 # -- Loading package STANDARD # -- Loading package TEXTIO # -- Loading package std_logic_1164 # -- Compiling entity lpm_constant0002 # -- Compiling architecture SYN of lpm_constant0002 # vcom -93 -work work {C:/Users/zjg/Desktop/FPGA/mode_change.vhd} # Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov 2 2012 # -- Loading package STANDARD # -- Loading package TEXTIO # -- Loading package std_logic_1164 # -- Loading package std_logic_arith # -- Loading package STD_LOGIC_UNSIGNED # -- Compiling entity mode_change # -- Compiling architecture behav of mode_change # # vcom -93 -work work {C:/Users/zjg/Desktop/FPGA/simulation/modelsim/abs.vht} # Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov 2 2012 # -- Loading package STANDARD # -- Loading package TEXTIO # -- Loading package std_logic_1164 # -- Compiling entity abs_vhd_tst # -- Compiling architecture abs_arch of abs_vhd_tst # # vsim -t 1ps -L altera -L lpm -L sgate -L altera_mf -L altera_lnsim -L cycloneii -L rtl_work -L work -voptargs="+acc" abs # vsim -L altera -L lpm -L sgate -L altera_mf -L altera_lnsim -L cycloneii -L rtl_work -L work -voptargs="+acc" -t 1ps abs # ** Error: (vsim-3170) Could not find 'C:/Users/zjg/Desktop/FPGA/simulation/modelsim/rtl_work.abs'. # # Error loading design # Error: Error loading design # Pausing macro execution # MACRO ./abs_run_msim_rtl_vhdl.do PAUSED at line 48 # A time value could not be extracted from the current line # A time value could not be extracted from the current line # A time value could not be extracted from the current line # A time value could not be extracted from the current line # A time value could not be extracted from the current line # A time value could not be extracted from the current line # A time value could not be extracted from the current line # A time value could not be extracted from the current line |
1434 浏览 1 评论
助力AIoT应用:在米尔FPGA开发板上实现Tiny YOLO V4
1059 浏览 0 评论
2513 浏览 1 评论
2206 浏览 0 评论
矩阵4x4个按键,如何把识别结果按编号01-16(十进制)显示在两个七段数码管上?
2475 浏览 0 评论
1931 浏览 53 评论
6021 浏览 113 评论
GMT+8, 2024-12-25 17:20 , Processed in 0.637597 second(s), Total 78, Slave 61 queries .
