可以尝试 http://processors.wiki.ti.com/index.php/Contiki-6LOWPAN 或 http://processors.wiki.ti.com/index.php/Cc26xx_sw_examples
This Getting Started section will show you how to create an Edge Router running Contiki in Linux on a BeagleBone Black (BBB) with CC2531 USB Dongle (2.4GHz) or a SmartRF06EB+CC13xxEM (sub-1GHz) as RF interface. CC13xx/CC26xx mesh devices (either SmartRF06EB-CC13xxEM/CC2650EM or CC2650 SensorTags acting as routers (RPL storing mode)) will connect to the Edge Router and use it to send their data. |
3312个成员聚集在这个小组
3168 浏览 1 评论
3817 浏览 0 评论
3329 浏览 0 评论
3860 浏览 1 评论
20427 浏览 11 评论
556浏览 2评论
541浏览 2评论
619浏览 1评论
714浏览 1评论
270浏览 1评论
GMT+8, 2024-9-21 22:02 , Processed in 0.581126 second(s), Total 45, Slave 39 queries .
