扫一扫,分享给好友
HI,大家好
请教一个C674x megamodule power down 的问题: The entire C674x megamodule can be powered-down using the following procedure. Other than the options previously specified, it is not possible to power-down only part of the C674x megamodule. Powering-down the C674x megamodule is completely under software control by programming the megamodule power-down (MEGPD) bit in the power-down controller command register (PDCCMD). The following software sequence is required to power-down the C674x megamodule: 1. Enable power-down by setting the MEGPD field to 1 in the PDCCMD register. 2. Enable the CPU interrupt(s) that you want to wake-up the C674x megamodule. Disable all other interrupts. 3. Execute the IDLE instruction. The C674x megamodule stays in a power-down state until awakened by the interrupt(s) that are enabled in step 2. 问题: 根据TI这个文档的描述,按照那三个步骤做了,但是不能让CPU进入IDLE, 没有生效。 code如下, 中间没有加enable 退出 power down状态的中断是因为系统中用到的两个中断随时都是enable起来的,所以没有必要重新在enable一次了,加了试了也不行。 HWREG(PDCCMD_REGS) |= 0x00010000; //PDCCMD_REGS defined as 0x01810000 asm("IDLE"); debug步骤如下: 1。首先查看了TSR寄存器的7:6 bit的值,确认已经是supervisor mode了。 2。写了PDCCMD寄存器之后,查看了寄存器的值,第16bit的MEGPD确实已经改成了1。 3。单步调试执行完这两句code之后,查看CSR寄存器的PWRD比特的值,发现还是0, 表示NO power down。 通过示波器测试也发现芯片应该没有进入power down的状态。 不知道各位大神以前有没有这方面的经验,求指教思密达,万分感谢!! |
1250 浏览 1 评论
556 浏览 0 评论
2509 浏览 0 评论
基于 DSP5509 进行数字图像处理中 Sobel 算子边缘检测的硬件连接电路图
4324 浏览 0 评论
870 浏览 0 评论
GMT+8, 2025-1-31 12:35 , Processed in 0.319528 second(s), Total 38, Slave 33 queries .
