Description: The Intel® Edison is an ultra small computing platform that will change the way you look at embedded electronics. Each Edison is packed with a huge amount of tech goodies into a tiny package while still providing the same robust strength of your go-to single board computer. Powered by the Intel® Atom™ SoC dual-core CPU and including an integrated WiFi, Bluetooth LE, and a 70-pin connector to attach a veritable slew of shield-like “Blocks” which can be stacked on top of each other. It’s no wonder how this little guy is lowering the barrier of entry on the world of electronics!
This I2C Block simply breaks out an I2C bus on the Intel® Edison while level shifting it from 1.8V to your sensors voltage. This a simple board that can snap into your Edison and be used right away. I2C_Breakout_Block SCH I2C_Breakout_Block SCH I2C_Breakout_Block PCB EasyEDA项目链接:https://easyeda.com/oshw/Block_for_Intel_Edison_I2C_Open_hardware-PYuoGWCEC EasyEDA链接: https://easyeda.com/ |
GMT+8, 2024-11-10 16:28 , Processed in 0.374126 second(s), Total 40, Slave 32 queries .
