Description: The Intel® Edison is an ultra small computing platform that will change the way you look at embedded electronics. Each Edison is packed with a huge amount of tech goodies into a tiny package while still providing the same robust strength of your go-to single board computer. Powered by the Intel® Atom™ SoC dual-core CPU and including an integrated WiFi, Bluetooth LE, and a 70-pin connector to attach a veritable slew of shield-like “Blocks” which can be stacked on top of each other. It’s no wonder how this little guy is lowering the barrier of entry on the world of electronics!
This Interface Starter Pack includes everything you need to get your Edison connected, essentially, any way you need. With this pack you will be able to snap four connector-type “Blocks” to your Edison to provide linking with I2C, PWM, ADC, or to motors via Dual H-Bridge. All you need to bring to this party is your own Intel® Edison. ADC_Block SCH ADC_Block SCH1 Dual_H-Bridge_Block SCH I2C_Breakout_Block SCH PWM_Block SCH ADC_Block PCB Dual_H-Bridge_Block PCB I2C_Breakout_Block PCB PWM_Block PCB EasyEDA项目链接:https://easyeda.com/oshw/Interface_Pack_for_Intel_Edison_Open_hardware-9lfxrI0iA EasyEDA链接: https://easyeda.com |
GMT+8, 2024-9-20 15:23 , Processed in 1.180635 second(s), Total 39, Slave 31 queries .
