扫一扫,分享给好友
module stopwatch (clk,out,reset,cin,ocom);
output [3:0] ocom; output [7:0] out; input cin,clk,reset; reg [7:0] out_ms,out_s; reg [7:0] out; reg [3:0] ocom; reg [3:0] in_out; reg clk_m,clk_n,clk_p; reg [1:0] select; reg [15:0] count_clk,count_cp,count_tp; always @ (posedge clk) begin if(count_cp==48000) //48MHZ做 48000次分频,取反后得到2ms的时间 begin count_tp=0; clk_n=~clk_n; end else count_cp=count_cp+1; end always @ (posedge clk) begin if(count_clk==24000000) //48MHZ做24000000次分频,取反后得到1s的时间 begin count_clk=0; clk_m=~clk_m; end else count_clk=count_clk+1; end always @ (posedge clk) begin if(count_tp==240000) //48MHZ做240000次分频,取反后得到0.01s的时间 begin count_tp=0; clk_p=~clk_p; end else count_tp=count_tp+1; end always @ (posedge clk_n) //2ms的数码管的扫描 select=select+1; always @ (select) //数码管的扫描 begin case(select) 2'b00:begin ocom[3:0]=4'b1110;in_out=out_ms[3:0];end 2'b01:begin ocom[3:0]=4'b1101;in_out=out_ms[7:4];end 2'b10:begin ocom[3:0]=4'b1011;in_out=out_s[3:0];end 2'b11:begin ocom[3:0]=4'b0111;in_out=out_s[7:4];end endcase end always @ (posedge clk_p or negedge reset) begin if(!reset) //若reset为低电平,四位数码管清零 begin out_ms<=0; out_s<=0; end else if(cin) begin if(out_ms[3:0]==9) begin out_ms[3:0]<=0; if(out_ms[7:4]==9) begin out_ms[7:4]<=0; if(out_s[3:0]==9) begin out_s[3:0]<=0; if(out_s[7:4]==5) out_s[7:4]<=0; else out_s[7:4]<=out_s[7:4]+1; end else out_s[3:0]<=out_s[3:0]+1; end else out_ms[7:4]<=out_ms[7:4]+1; end else out_ms[3:0]<=out_ms[3:0]+1; end end always @ (in_out) begin case(in_out) //将要显示的数字译成段码 4'b0000://0 out[7:0]=8'b0000_0011; 4'b0001://1 out[7:0]=8'b1001_1111; 4'b0010://2 out[7:0]=8'b0010_0101; 4'b0011://3 out[7:0]=8'b0000_1101; 4'b0100://4 out[7:0]=8'b1001_1001; 4'b0101://5 out[7:0]=8'b0100_1001; 4'b0110://6 out[7:0]=8'b0100_0001; 4'b0111://7 out[7:0]=8'b0001_1111; 4'b1000://8 out[7:0]=8'b0000_0001; 4'b1001://9 out[7:0]=8'b0000_1001; default: //这里仅编译了0-9这几个数字 out[7:0]=8'b1111_1111; //全灭 endcase end endmodule 为什么四位数码管一直显示的为零 |
请仔细检查逗号和分号
1686 浏览 1 评论
助力AIoT应用:在米尔FPGA开发板上实现Tiny YOLO V4
1096 浏览 0 评论
2775 浏览 1 评论
2454 浏览 0 评论
矩阵4x4个按键,如何把识别结果按编号01-16(十进制)显示在两个七段数码管上?
2745 浏览 0 评论
2084 浏览 56 评论
6069 浏览 113 评论
GMT+8, 2025-1-3 05:53 , Processed in 0.415041 second(s), Total 36, Slave 31 queries .
