扫一扫,分享给好友
在文档里面,写着这样的一段
The I2C bus uses two wires to transfer information between devices connected to the bus: “SCL” (serial clock line) and “SDA” (serial data line). The I2C component requires the use of external open-drain buffers since it has only unidirectional ports. The “SDA” and “SCL” lines referred further are the actual I2C bus signals, while the I2C component is connected to them with the use of open-drains (“SDAO” as output and “SDAI” as input, “SCLO” as output and “SCLI” as input). Each device connected to the bus is software addressable by a unique address. The I2C is a true multi-master bus including collision detection and arbitration to prevent data corruption if two or more masters simultaneously initiate data transfer. The filtering logic rejects spikes on the bus data line to preserve data integrity. 请问各位,这两个IO是不是还要接什么东西么?我现在直接使用芯片的IO,操作没有I2C的信号出来。 |
7个回答
各上拉2.2k到电源,
求指导
看不懂
自己网上查了下,问了下同事,说一般都加上拉电阻,其阻值4.7K或者10K, 然后在网上查了下http://m.blog.csdn.net/blog/mick_ye/20553141这里有个说明。我用的这个芯片,内含有上拉电阻,但实际的阻值有多大没看到,可能没细看或者文档没写到。
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-Pinctrl和GPIO子系统之ioctl介绍
556 浏览 0 评论
1121 浏览 1 评论
《DNESP32S3使用指南-IDF版_V1.6》第五十九章 人脸识别实验
1334 浏览 0 评论
进程、线程、协程傻傻分不清?一文带你彻底扒光它们的\"底裤\"!
805 浏览 0 评论
FreeRTOS进阶使用之流缓冲区:高效处理字节流的秘密武器
1007 浏览 0 评论
12650 浏览 31 评论
GMT+8, 2025-3-30 01:45 , Processed in 0.511611 second(s), Total 50, Slave 44 queries .
