最近在做用STM8L152驱动段式LCD,该IC有专用的LCD接口,可以实现显示,但是在实现段位闪烁的地方卡住了,以下是库函数:
/** * @brief Configures the LCD Blink mode and Blink frequency. * @param LCD_BlinkMode: specifies the LCD blink mode. * This parameter can be one of the following values: * @arg LCD_BlinkMode_Off: Blink disabled * @arg LCD_BlinkMode_SEG0_COM0: Blink enabled on SEG[0], COM[0] (1 pixel) * @arg LCD_BlinkMode_SEG0_AllCOM: Blink enabled on SEG[0], all COM (up to 8 * pixels according to the programmed duty) * @arg LCD_BlinkMode_AllSEG_AllCOM: Blink enabled on all SEG and all COM * (all pixels) * @param LCD_BlinkFrequency: specifies the LCD blink frequency. * This parameter can be one of the following values: * @arg LCD_BlinkFrequency_Div8: The Blink frequency = fLcd/8 * @arg LCD_BlinkFrequency_Div16: The Blink frequency = fLcd/16 * @arg LCD_BlinkFrequency_Div32: The Blink frequency = fLcd/32 * @arg LCD_BlinkFrequency_Div64: The Blink frequency = fLcd/64 * @arg LCD_BlinkFrequency_Div128: The Blink frequency = fLcd/128 * @arg LCD_BlinkFrequency_Div256: The Blink frequency = fLcd/256 * @arg LCD_BlinkFrequency_Div512: The Blink frequency = fLcd/512 * @arg LCD_BlinkFrequency_Div1024: The Blink frequency = fLcd/1024 * @retval None */ void LCD_BlinkConfig(LCD_BlinkMode_TypeDef LCD_BlinkMode, LCD_BlinkFrequency_TypeDef LCD_BlinkFrequency) { /* Check function parameters */ assert_param(IS_LCD_BLINK_MODE(LCD_BlinkMode)); assert_param(IS_LCD_BLINK_FREQUENCY(LCD_BlinkFrequency)); LCD->CR1 &= (uint8_t)(~LCD_CR1_BLINK); /* Clear the blink mode bits */ LCD->CR1 |= LCD_BlinkMode; /* Config the LCD Blink Mode */ LCD->CR1 &= (uint8_t)(~LCD_CR1_BLINKF); /* Clear the blink frequency bits */ LCD->CR1 |= LCD_BlinkFrequency; /* Config the LCD Blink Frequency */ } 配置段位闪烁(就是电子表中间那两个小点的类似闪烁),因为每一段都要设置,设置的时候要求它闪烁,但是这个函数只能配置4种状态,全开全关,COM0-SEG0,SEG0-所有COM口,不能实现任意像素点闪烁吗?比如要要求COM3-SEG7这个段位闪烁?怎么显示,有没有大神操作过? |
3个回答
没有大神知道么 自己顶一下
单独写他对应的LCD_RAM的地址
可以,只是你的需要把LCD的笔端取出来写,像写LED数码管一样。不用采用,EVA板上面的好种方式驱动显示
STM32配合可编程加密芯片SMEC88ST的防抄板加密方案设计
1104 浏览 0 评论
2438 浏览 1 评论
AD7686芯片不传输数据给STM32,但是手按住就会有数据。
2228 浏览 3 评论
4866 浏览 0 评论
如何解决MPU-9250与STM32通讯时,出现HAL_ERROR = 0x01U
2374 浏览 1 评论
GMT+8, 2025-1-1 09:19 , Processed in 0.506637 second(s), Total 45, Slave 38 queries .
