用了quartus II自带的宏模块 做了两个双口ram 实现缓存一行数据 我用modelsim一直仿真不出来 testbench提示我 cnt没有定义 但是cnt是 程序里面的reg不是不用定义吗??
不知道写得对不对 是不是用两个ram就要使用乒乓操作??? 下面是例程 顶层文件-------------------------------------------------------------------------------- module m9k_two( input [15:0] Data, input clk_wr, input clk_rd, input rst_n, input wren_1, input wren_2, input rden_1, input rden_2, output [15:0] set_out_1, output [15:0] set_out_2); //----------------------------------------------------- wire [3:0] wraddress_1; wire [3:0] rdaddress_1; wire [3:0] wraddress_2; wire [3:0] rdaddress_2; wire [15:0] data_1; wire [15:0] data_2; //----------------------------------------------------- //双口模块1 ram_1 ram_1_u( .data(data_1), .wraddress(wraddress_1), .wren(wren_1), .wrclock(clk_wr), //--------------------------------- .rdaddress(rdaddress_1), .rden(rden_1), .rdclock(clk_rd), .q(set_out_1) ); //----------------------------------------------------- //双口模块2 ram_2 ram_2_u( .data(data_2), .wraddress(wraddress_2), .wren(wren_2), .wrclock(clk_wr), //--------------------------------- .rdaddress(rdaddress_2), .rden(rden_2), .rdclock(clk_rd), .q(set_out_2) ); //----------------------------------------------------- //RAM控制模块 ram_top ram_top_u( .clk_wr(clk_wr), .clk_rd(clk_rd), .data(Data), .rst_n(rst_n), .wraddress_1(wraddress_1), .rdaddress_1(rdaddress_1), // .wren_1(wren_1), // .rden_1(rden_1), .data_1(data_1), .wraddress_2(wraddress_2), .rdaddress_2(rdaddress_2), // .wren_2(wren_2), // .rden_2(rden_2), .data_2(data_2) ); endmodule 控制程序--------------------------------------------------------------------------------------------------- module ram_top( input clk_wr, input clk_rd, input [15:0] data, input rst_n, output [3:0] wraddress_1, output [3:0] rdaddress_1, //output wren_1, //output rden_1, output [15:0] data_1, output [3:0] wraddress_2, output [3:0] rdaddress_2, //output wren_2, //output rden_2, output [15:0] data_2 ); //----------------------------------------------- //读地址控制模块 reg [3:0]wraddress_1_1; reg [3:0]wraddress_2_2; assign wraddress_1=wraddress_1_1; assign wraddress_2=wraddress_2_2; always@(posedge clk_wr or negedge rst_n) begin if(!rst_n) begin wraddress_1_1<=4'b0; wraddress_2_2<=4'b0; end else begin wraddress_1_1<=wraddress_1_1+1; wraddress_2_2<=wraddress_2_2+1; end end //----------------------------------------------- //写地址控制模块 reg [3:0]rdaddress_1_1; reg [3:0]rdaddress_2_2; assign rdaddress_1=rdaddress_1_1; assign rdaddress_2=rdaddress_2_2; always@(posedge clk_rd or negedge rst_n) begin if(!rst_n) begin rdaddress_1_1<=4'b0; rdaddress_2_2<=4'b0; end else begin rdaddress_1_1<=rdaddress_1_1+1; rdaddress_2_2<=rdaddress_2_2+1; end end //----------------------------------------------- //数据流 reg [15:0]data_1_1; reg [15:0]data_2_2; assign data_1=data_1_1; assign data_2=data_2_2; always@(posedge clk_wr or negedge rst_n) begin if(!rst_n) begin data_1_1<=16'b0; data_2_2<=16'b0; end else begin if((cnt=1)||(cnt=2)||(cnt=3)) data_1_1<=data; else data_2_2<=data; end end //----------------------------------------------- //数据计数 reg [3:0] cnt; always@(posedge clk_wr or negedge rst_n) begin if(!rst_n) cnt<=4'b0; else if(cnt<8) cnt<=cnt+1; else cnt<=cnt; end endmodule testbench 文件程序 `timescale 1 ns/ 1 ns module m9k_two_vlg_tst(); reg [15:0] Data; reg clk_rd; reg clk_wr; reg rden_1; reg rden_2; reg rst_n; reg wren_1; reg wren_2; wire [15:0] set_out_1; wire [15:0] set_out_2; m9k_two i1 ( .Data(Data), .clk_rd(clk_rd), .clk_wr(clk_wr), .rden_1(rden_1), .rden_2(rden_2), .rst_n(rst_n), .set_out_1(set_out_1), .set_out_2(set_out_2), .wren_1(wren_1), .wren_2(wren_2) ); //------------------------------------------------复位 initial begin rst_n=1'b1; #10 rst_=1'b0; end //------------------------------------------------读时钟 initial begin clk_rd=1'b0; forever #10 clk_rd= ~clk_rd; end //------------------------------------------------写时钟 initial begin clk_wr=1'b0; forever #5 clk_wr= ~clk_wr; end //------------------------------------------------模块使能端 initial begin wren_1=1'b1; rden_1=1'b1; wren_2=1'b1; rden_2=1'b1; end //------------------------------------------------ initial //顺序结构 begin // wren = 0; Data = 16'd0; #10 Data = 16'd11; #10 Data = 16'd22; #10 Data = 16'd33; #10 Data = 16'd44; #10 Data = 16'd55; #10 Data = 16'd66; #10 Data = 16'd77; end endmodule |
3个回答
我最近也在做这个方面的东西,希望大神门讲解一下
功能没了解
modelsim里面不管是REG还是WIRE,在使用前都需要有声明,就是在位置上要先声明再使用,不然就会有报错说未定义,然后又说重复定义 另外你那个cnt的判断语句能编译过去?! |
DemonWAR 发表于 2015-10-30 22:25 我已经找到问题了 原来是没有把testbench文件加入 modelsim 还是谢谢你了 |
466 浏览 0 评论
AG32软件包SDK更新:加入新例程(可实现至少15个UART串口)
1159 浏览 0 评论
从零开始驯服Linux(一):ZYNQ-Linux启动文件构建全解析
2009 浏览 0 评论
AG32 SDK 更新版本1.7.0:加入dsp例程和Slave SPI例程
639 浏览 0 评论
1244 浏览 0 评论
6512 浏览 114 评论
2609 浏览 58 评论
GMT+8, 2025-4-2 04:04 , Processed in 0.687136 second(s), Total 75, Slave 58 queries .
