Characterizing and Modeling the Impact of Power/Ground Via Arrays on Power Plane Impedance
Abstract In this paper, the impact of power/ground via arrays on power plane impedance is studied. 8 x 8 via array structures are characterized and the results are compared to fullwave field simulation using HFSS. These results show that the impedance and effective inductance is a strong function of location within the array. The lowest impedance is found on the array perimeter and the impedance is several times higher in the array center. The impact antipad size and dielectric thickness on the plane impedance and inductance is examined using parameterized models. ![]() |
1578 浏览 0 评论
9203 浏览 0 评论
7252 浏览 0 评论
7895 浏览 0 评论
5398 浏览 2 评论
GMT+8, 2025-3-7 01:03 , Processed in 0.493219 second(s), Total 69, Slave 50 queries .
