一个项目里有IP核rom,想改其中的参数重新生成,结果打开失败,然后我把它移除了,在项目里边新添加不了,提示如下错误ERROR:sim - Failed to run command ' -cg_exc_inp "D:/ISE/dds/ipcore_dir/tmp/_cg/_dbg/xil_318.in" -cg_exc_out "D:/ISE/dds/ipcore_dir/tmp/_cg/_dbg/xil_318.out" -namelock'. Executable file not found. ERROR:sim - Failed executing Tcl generator. ERROR:sim - Failed to generate 'lookup_table'. Failed executing Tcl generator. 然后我新建工程,添加IPcore时也是这个错误,现在添加IP核时都是这个错误。我百度有个人有同样的问题,他说解决了,但说的我不是很明白It was not a ISE problem. The directory of the project has a limited space. My fault. 感觉像是手贱点错了,大家看看知不知道是什么问题 |
3个回答
ISE BUG挺多的,重新新建一个快些。注意顺序。
GMT+8, 2024-9-21 08:41 , Processed in 0.411112 second(s), Total 41, Slave 36 queries .
