扫一扫,分享给好友
各位好,我这段时间弄STM8L151的I2C与MTK处理器的手机的I2C通信(手机I2C的程序是另一个人写的),弄了一个多星期没搞定。不知道是哪里的原因,我用俩个单片机通信,一个作主机,另一个作从
机(从机接收用中断方式),主机可以正常向从机收发数据,当手机作主机时,一个单片机作从机就出问题了,从机地址匹配正确后不断地进入中断。强制在中断中打印中断事件值为0x6D0。手机电平( 1.8V)已经过电平芯片转换成3.3V电平。用示波器量手机I2C时SCL有一个正脉冲,SDA没响应。希望高手可以给我指出问题。我的代码如下: 主机代码(Master) INTERRUPT_HANDLER(I2C1_SPI2_IRQHandler, 29) { switch (I2C_GetLastEvent(I2C1)) { /* EV5 */ case I2C_EVENT_MASTER_MODE_SELECT : /* Send slave Address for write */ //I2C_Direction_Receiver I2C_Direction_Transmitter I2C_Send7bitAddress(I2C1, SLAVE_ADDRESS, I2C_Direction_Transmitter); break; /* EV6 */ case I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED: break; /* EV8 */ case I2C_EVENT_MASTER_BYTE_TRANSMITTING: /* Transmit Data */ I2C_SendData(I2C1,5); break; /* EV8_2 */ case I2C_EVENT_MASTER_BYTE_TRANSMITTED: /* Send STOP condition */ I2C_GenerateSTOP(I2C1, ENABLE); I2C_ITConfig(I2C1, I2C_IT_EVT, DISABLE); break; default: break; } } void main() { /* I2C clock Enable*/ CLK_PeripheralClockConfig(CLK_Peripheral_I2C1, ENABLE); /* system_clock / 1 */ CLK_SYSCLKDivConfig(CLK_SYSCLKDiv_1); /* Initialize I2C peripheral */ I2C_Init(I2C1, I2C_SPEED, 0xA0, I2C_Mode_I2C, I2C_DutyCycle_2, I2C_Ack_Enable, I2C_AcknowledgedAddress_7bit); /* Enable Buffer and Event Interrupt*/ I2C_ITConfig(I2C1, (I2C_IT_TypeDef)(I2C_IT_EVT | I2C_IT_BUF) , ENABLE); enableInterrupts(); /* TXBuffer initialization */ for (i = 0; i < BUFFERSIZE; i++) TxBuffer[i] = i; USART1_INIT(); printf("I2C test!rn"); I2C_GenerateSTART(I2C1, ENABLE); printf("2C_IT = 1;rn"); while (1) { /***** reception phase ***/ /* Wait while the bus is busy */ while (I2C_GetFlagStatus(I2C1, I2C_FLAG_BUSY)); /* Test on EV5 and clear it */ while (!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT)); /* Send slave Address for write */ I2C_Send7bitAddress(I2C1, SLAVE_ADDRESS, I2C_Direction_Receiver); /* Test on EV6 and clear it */ while (!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED)); /* Disable Acknowledgement */ I2C_AcknowledgeConfig(I2C1, DISABLE); /* Send STOP Condition */ I2C_GenerateSTOP(I2C1, ENABLE); /* Poll on RxNE Flag */ while ((I2C_GetFlagStatus(I2C1, I2C_FLAG_RXNE) == RESET)); /* Read a byte from the Slave */ RxBuffer[0] = I2C_ReceiveData(I2C1); printf("RxBuffer[0] = 0x%xrn",RxBuffer[0]); } } 从机代码(Slave): INTERRUPT_HANDLER(I2C1_SPI2_IRQHandler, 29) { /* Read SR2 register to get I2C error */ if(I2C_ReadRegister(I2C1, I2C_Register_SR2)) { /* Clears SR2 register */ I2C1->SR2 = 0; /* Set LED2 */ } switch (I2C_GetLastEvent(I2C1)) { /******* Slave transmitter ******/ /* check on EV1*/ case I2C_EVENT_SLAVE_RECEIVER_ADDRESS_MATCHED: Rx_Idx = 0; I2C_state[0] = 1; break; /* Check on EV2*/ case I2C_EVENT_SLAVE_BYTE_RECEIVED: Slave_Buffer_Rx[0] = I2C_ReceiveData(I2C1); I2C_state[1] = 1; break; /******* Slave transmitter ******/ /* check on EV1 */ case I2C_EVENT_SLAVE_TRANSMITTER_ADDRESS_MATCHED: I2C_state[2] = 1; break; /* check on EV3 */ case I2C_EVENT_SLAVE_BYTE_TRANSMITTING: GPIO_ResetBits(GPIOA,GPIO_Pin_6); /* Transmit data */ I2C_SendData(I2C1, 0x48); I2C_state[3] = 1; break; /* Check on EV4 */ case (I2C_EVENT_SLAVE_STOP_DETECTED): //GPIO_ResetBits(GPIOA,GPIO_Pin_6); /* write to CR2 to clear STOPF flag */ Rx_Idx = 0; I2C_state[4] = 1; I2C_state[5] = 1; I2C1->CR2 |= I2C_CR2_ACK; break; default: break; } } void main(void) { int i=0; //initialize I2C GPIO PC0-->I2C_SDA PC1-->I2C_SCL //GPIO_Init(GPIOC, GPIO_Pin_0 | GPIO_Pin_1, GPIO_Mode_Out_OD_HiZ_Fast); /* system_clock / 1 */ CLK_SYSCLKDivConfig(CLK_SYSCLKDiv_1); /* I2C clock Enable*/ CLK_PeripheralClockConfig(CLK_Peripheral_I2C1, ENABLE); USART1_INIT(); LED_INIT(); I2C_DeInit(I2C1); I2C_Cmd(I2C1, ENABLE); I2C_AcknowledgeConfig(I2C1, ENABLE); /* Initialize I2C peripheral */ I2C_Init(I2C1, 100000, SLAVE_ADDRESS, I2C_Mode_I2C, I2C_DutyCycle_2, I2C_Ack_Enable, I2C_AcknowledgedAddress_7bit); /* Enable Error Interrupt*/// I2C_ITConfig(I2C1, (I2C_IT_TypeDef)(I2C_IT_ERR |I2C_IT_EVT |I2C_IT_BUF), ENABLE); /* Enable general interrupts */ enableInterrupts(); GPIO_SetBits(GPIOA,GPIO_Pin_6); printf("I2C test!rn"); /*Main Loop */ while (1) { Delay(0x5000); GPIO_SetBits(GPIOA,GPIO_Pin_6); GPIO_SetBits(GPIOA,GPIO_Pin_5); Delay(0x5000); GPIO_ResetBits(GPIOA,GPIO_Pin_5); if(I2C_state[5] == 1) { if(I2C_state[0] == 1) { DEBUG("从机地址匹配正确"); //GPIO_ResetBits(GPIOA,GPIO_Pin_6); } if(I2C_state[1] == 1) { DEBUG("从机接收到数据"); printf("Slave_Buffer_Rx[0] = %drn",Slave_Buffer_Rx[0]); i++; //GPIO_ResetBits(GPIOA,GPIO_Pin_6); } if(I2C_state[2] == 1) { DEBUG("发送地址匹配"); } if(I2C_state[3] == 1) { DEBUG("从机发送数据"); } if(I2C_state[4] == 1) { DEBUG("通信结束"); } if(aaa == 100) { aaa=0; DEBUG(" 56415312"); } for(i=0;i<6;i++) { I2C_state[i] = 0; } } } } |
4个回答
谢谢。弄得了,手机那边的波特率没设好。 |
学习学习一下!!!
1365 浏览 0 评论
国产NSI1300D05-DSWVR放大芯片放大增益8.2或41的问题
1358 浏览 0 评论
STM32串口接受中断使用C++STL中的queue导致所有中断失效
8895 浏览 1 评论
3648 浏览 0 评论
STM32配合可编程加密芯片SMEC88ST的防抄板加密方案设计
1580 浏览 0 评论
GMT+8, 2025-3-6 22:47 , Processed in 0.576903 second(s), Total 79, Slave 63 queries .
