// MSP-FET430P140 Demo - USART0, Ultra-Low Pwr UART 9600 Echo ISR, 32kHz ACLK // // Description: Echo a received character, RX ISR used. In the Mainloop UART0 // is made ready to receive one character with interrupt active. The Mainloop // waits in LPM3. The UART0 ISR forces the Mainloop to exit LPM3 after // receiving one character which echo's back the received character. // ACLK = UCLK0 = LFXT1 = 32768, MCLK = SMCLK = DCO~ 800k // Baud rate divider with 32768hz XTAL @9600 = 32768Hz/9600 = 3.41 (0003h 4Ah ) // //* An external watch crystal is required on XIN XOUT for ACLK *// // // MSP430F149 // ----------------- // /|| XIN|- // | | | 32kHz // --|RST XOUT|- // | | // | P3.4|-----------> // | | 9600 - 8N1 // | P3.5|<----------- // // // M. Buccini // Texas Instruments Inc. // Feb 2005 // Built with IAR Embedded Workbench Version: 3.21A //****************************************************************************** #include void main(void) { P6DIR |= BIT2;P6OUT |= BIT2; //关电平转换 WDTCTL = WDTPW + WDTHOLD; // Stop WDT P3SEL |= 0x30; // P3.4,5 = USART0 TXD/RXD ME1 |= UTXE0 + URXE0; // Enable USART0 TXD/RXD UCTL0 |= CHAR; // 8-bit character UTCTL0 |= SSEL0; // UCLK = ACLK UBR00 = 0x03; // 32k/9600 - 3.41 UBR10 = 0x00; // UMCTL0 = 0x4A; // Modulation UCTL0 &= ~SWRST; // Initialize USART state machine IE1 |= URXIE0; // Enable USART0 RX interrupt // Mainloop for (;;) { _BIS_SR(LPM3_bits + GIE); // Enter LPM3 w/interrupt while (!(IFG1 & UTXIFG0)); // USART0 TX buffer ready? TXBUF0 = RXBUF0; // RXBUF0 to TXBUF0 } } // UART0 RX ISR will for exit from LPM3 in Mainloop #pragma vector=UART0RX_VECTOR __interrupt void usart0_rx (void) { _BIC_SR_IRQ(LPM3_bits); // Clear LPM3 bits from 0(SR) } 这是我149开发板上的程序,你要用到449去只要稍微改下寄存器即可,结构就是这样,望对你有用 |
3012个成员聚集在这个小组
加入小组2892 浏览 1 评论
MSP430FR5994 使用库函数 定时器触发AD问题请教
3407 浏览 2 评论
请问怎么把下面51单片机的代码改成msp430 g2 pocket的代码,还有改下时间变成30秒
2322 浏览 1 评论
4781 浏览 1 评论
2556 浏览 1 评论
1297浏览 3评论
3411浏览 2评论
2897浏览 1评论
1457浏览 0评论
GMT+8, 2024-11-10 20:07 , Processed in 1.207761 second(s), Total 79, Slave 63 queries .
