基于ise14.7
下面是一个时钟脉冲的Verilog程序,但是编译总是无法通过,检查也检查不出问题,求大神赐教!!! module clock_pulse( input wire inp, input wire cclk, input wire clr, output wire outp ); reg delay1; reg delay2; reg delay3; always@(posedge cclk or negedge clr) begin if(clr==1'b1) begin delay1<=0; delay2<=0; delay3<=0; end else begin delay1<=inp; delay2<=delay1; delay3<=delay2; end end assign outp=delay1 & delay2 & ~delay3;//产生时钟脉冲 endmodule 注: 编译时提示的错误是:ERROR:HDLCompiler:1128 - "E:ISE-FPGA Procedureclock_pulseclock_pulse.v" Line 41: Assignment under multiple single edges is not supported for synthesis 警告有: WARNING:HDLCompiler:462 - "E:ISE-FPGA Procedureclock_pulseclock_pulse.v" Line 33: if-condition does not match any sensitivity list edge WARNING:HDLCompiler:91 - "E:ISE-FPGA Procedureclock_pulseclock_pulse.v" Line 41: Signal WARNING:HDLCompiler:1499 - "E:ISE-FPGA Procedureclock_pulseclock_pulse.v" Line 21: Empty module |
3个回答
确实是被多个时钟沿驱动,这里不允许的情况下,你可以尝试将边沿触发改为电平触发
最佳答案
很明显你的异步复位没写对!改为if(clr==1’b0)就可以了
基本FPGA或者树莓派或者其它微处理器(尽量压缩成本且完成项目)DFB激光器稳频
1449 浏览 1 评论
2542 浏览 1 评论
助力AIoT应用:在米尔FPGA开发板上实现Tiny YOLO V4
1203 浏览 0 评论
3693 浏览 1 评论
3303 浏览 0 评论
2336 浏览 58 评论
6190 浏览 113 评论
GMT+8, 2025-2-2 13:42 , Processed in 0.616757 second(s), Total 41, Slave 36 queries .
