【Z-turn Board试用体验】+下载时候出现了问题,请问米尔工程师怎么解决的啊?急呢! - 问答 - 电子威廉希尔官方网站 论坛 - 最好最受欢迎电子论坛!
何立立 ( 楼主 ) 2015-7-6 20:27:31  只看该作者 倒序浏览
(1)ISE14.7    在用imapcat下载配置文件到板子的时候,JTAG链是可以扫描出来的
但是在下载配置文件 program 时会失败,出现一下错误:
Boundary-scan chain validated successfully.
2: Device Temperature: Current Reading:   43.48 C, Min. Reading: -273.00 C, Max. Reading:   43.98 C
2: VCCINT Supply: Current Reading:   1.005 V, Min. Reading:   0.000 V, Max. Reading:   1.005 V
2: VCCAUX Supply: Current Reading:   1.799 V, Min. Reading:   0.000 V, Max. Reading:   1.802 V
INFO:iMPACT:583 - '2': The idcode read from the device does not match the idcode in the bsdl File.
INFO:iMPACT:1578 - '2':  Device IDCODE :        00000000000000000000000000000000
INFO:iMPACT:1579 - '2': Expected IDCODE:    00000011011100100010000010010011
INFO:iMPACT - Creating XC7Z010 device.
PROGRESS_START - Starting Operation.
INFO:Cse - Failed to initialize the zynq device.
'2': Programming device...
done.
INFO:Cse - Error shows in the status register, release done bit is NOT 1.
INFO:Cse - Status register values:
INFO:Cse - 0000 0000 0000 0000 0000 0000 0000 0000
PROGRESS_END - End Operation.
Elapsed time =     58 sec.
我换了排线也不行。我的xilinx下载器没问题,因为在其它板子上是可以用的。
(2)
换用vivado 2014.2软件后,用vivado内的 hardware session 下载时候,也不能下载进去的,会出现如下错误:
下载到99%的时候进度条不动了,且出现警告提示:
   WARNING: [Labtools 27-33] Done pin status: LOW
(3)换了只新的下载器,impact 下载还是失败:提示
INFO:iMPACT:501 - '2': Added Device xc7z010 successfully.
INFO:iMPACT - Current time: 2015/7/7 11:52:41
Maximum TCK operating frequency for this device chain: 20000000.
Validating chain...
2: Device Temperature: Current Reading:   39.05 C, Min. Reading:   32.16 C, Max. Reading:   39.55 C
2: VCCINT Supply: Current Reading:   1.005 V, Min. Reading:   1.002 V, Max. Reading:   1.005 V
2: VCCAUX Supply: Current Reading:   1.802 V, Min. Reading:   1.799 V, Max. Reading:   1.802 V
done.
Elapsed time =     57 sec.
Match_cycle = NoWait.
Match cycle: NoWait
LCK_cycle = NoWait.
LCK cycle: NoWait
INFO:iMPACT - '2': Checking done pin....done.
'2': Programming terminated. DONE did not go high.
[size=14.3999996185303px]请问是怎么解决的,这个问题已经困扰我好几天了。
7个回复
何立立 发表于 2015-7-7 22:59:23
米尔威廉希尔官方网站 支持工程师 在跟我邮件来往了 在帮助解决问题,非常谢谢
中科院 发表于 2015-7-8 00:31:02
怎么样?arm jtag有时也是会出现PIN low的问题
在继续解决中 昨天方法不行。
gwwjn 发表于 2015-7-24 22:04:22
你可以看下是不是有信号没有分配管脚
你可以看下是不是有信号没有分配管脚
不是的,拐角分配没有问题
238801 发表于 2015-12-1 21:10:14
请问楼主解决问题了吗?我也遇到这个问题
陆润新 发表于 2015-12-2 15:36:07
新手、入门的兄弟姐妹可以加群咱相互交流学习哈,FPGA入门学习交流群 466511993
您需要登录后才可以回帖 登录 | 注册
本版积分规则
站长推荐上一条 /6 下一条
小黑屋|手机版|Archiver|电子发烧友 ( 湘ICP备2023018690号 )
GMT+8, 2025-7-6 09:30 , Processed in 0.539516 second(s), Total 42, Slave 33 queries .
微信扫描
