[BR]Calibration Procedure for Video EquipmentProducts:CCVS + COMPONENT GENERATOR SAFCCVS GENERATOR SFFTV GENERATORS SG.FVIDEO ANALYZER UAFVIDEO MEASUREMENT SYSTEM VSACalibration Procedure for Video EquipmentSince the video signal - composite or component - is a most complex one regardingthe spectral density or even the group delay in the baseband, you need specialprocedures to measure the signal parameters with an objective and absoluteaccuracy of less than one percent over the whole frequency range up to 6 MHz.The following describes a method allowing the precise measurement of a basebandsignal, which then may be taken for the calibration of video analyzers such as thewell-known R&S units UAF or UVF and future products.How to measure the level of low frequency signal elements like thewhite bar
544个成员聚集在这个小组
加入小组Prolith和HyperLith主要用于mask-in-stepper lithography仿真、光刻设计
351浏览 1评论
4316浏览 0评论
GMT+8, 2025-2-23 14:56 , Processed in 0.579312 second(s), Total 41, Slave 33 queries .
