一直想搞一下四轴飞行器,不过总是么有时间,前段时间在家休息,好好研究一下四轴飞行器的PID算法。现在凑个热闹,分享传说中的串级PID,内环为角速度环,外环为角速度。整定PID参数的时候先调外环,再调内环。
不多说,先上文件:
想直接看的可以看看这个代码,都是一样的
- #include "CONTROL.h"
- #include "IMU1.h"
- #include "moto.h"
- #include "RFdate.h"
- #include
- extern T_RC_Data Rc_D; //遥控通道数据;
- extern u8 txbuf[4]; //发送缓冲
- extern u8 rxbuf[4]; //接收缓冲
- extern u16 test1[3]; //接收到NRf24L01数据
- extern S_INT16_XYZ ACC_F,GYRO_F;
- PID PID_ROL,PID_PIT,PID_YAW;
- extern S_INT16_XYZ MPU6050_ACC_LAST,MPU6050_GYRO_LAST;
- int Motor_Ele=0; //俯仰期望
- int Motor_Ail=0; //横滚期望
- //u8 ARMED = 0;
- //float rol_i=0,pit_i=0,yaw_p=0;
- float thr=0;
- S_FLOAT_XYZ EXP_ANGLE ,DIF_ANGLE;
- PID1 PID_Motor;
- float Pitch_i,Roll_i,Yaw_i; //积分项
- float Pitch_old,Roll_old,Yaw_old; //角度保存
- float Pitch_d,Roll_d,Yaw_d; //微分项
- float RC_Pitch,RC_Roll,RC_Yaw; //姿态角
- float Pitch_shell_out,Roll_shell_out,Yaw_shell_out;//外环总输出
- //外环PID参数
- float Pitch_shell_kp=280;//30 140
- float Pitch_shell_kd=0;//
- float Pitch_shell_ki=0;//
- float Roll_shell_kp=250;//30
- float Roll_shell_kd=0;//10
- float Roll_shell_ki=0;//0.08
- float Yaw_shell_kp=1.5;//10;//30
- float Yaw_shell_kd=0;//10
- float Yaw_shell_ki=0;//0.08;//0.08
- float Gyro_radian_old_x,Gyro_radian_old_y,Gyro_radian_old_z;//陀螺仪保存
- float pitch_core_kp_out,pitch_core_kd_out,Roll_core_kp_out,Roll_core_kd_out,Yaw_core_kp_out,Yaw_core_kd_out;//内环单项输出
- float Pitch_core_out,Roll_core_out,Yaw_core_out;//内环总输出
- //内环PID参数
- //float Pitch_core_kp=0.040;
- //float Pitch_core_kd=0.008;////0.007;//0.07;
- float Pitch_core_kp=0.040;
- float Pitch_core_kd=0.002;////0.007;//0.07;
- float Roll_core_kp=0.040;//;
- float Roll_core_kd=0.002;////0.007;//06;//0.07;
- float Yaw_core_kp=0.046;//;
- float Yaw_core_kd=0.012;////0.007;//06;//0.07;
- int16_t moto1=0,moto2=0,moto3=0,moto4=0;
- float tempjd=0;
- void CONTROL(float rol, float pit, float yaw)
- RC_Pitch=(Rc_D.PITCH-1500)/20;
- ////////////////////////外环角度环(PID)///////////////////////////////
- Pitch_i+=(Q_ANGLE.Pitch-RC_Pitch);
- //-------------Pitch积分限幅----------------//
- if(Pitch_i>300) Pitch_i=300;
- else if(Pitch_i<-300) Pitch_i=-300;
- //-------------Pitch微分--------------------//
- Pitch_d=Q_ANGLE.Pitch-Pitch_old;
- //-------------Pitch PID-------------------//
- Pitch_shell_out = Pitch_shell_kp*(Q_ANGLE.Pitch-RC_Pitch) + Pitch_shell_ki*Pitch_i + Pitch_shell_kd*Pitch_d;
- //角度保存
- Pitch_old=Q_ANGLE.Pitch;
- RC_Roll=(Rc_D.ROLL-1500)/20;
- Roll_i+=(Q_ANGLE.Rool-RC_Roll);
- //-------------Roll积分限幅----------------//
- if(Roll_i>300) Roll_i=300;
- else if(Roll_i<-300) Roll_i=-300;
- //-------------Roll微分--------------------//
- Roll_d=Q_ANGLE.Rool-Roll_old;
- //-------------Roll PID-------------------//
- Roll_shell_out = Roll_shell_kp*(Q_ANGLE.Rool-RC_Roll) + Roll_shell_ki*Roll_i + Roll_shell_kd*Roll_d;
- //------------Roll角度保存------------------//
- Roll_old=Q_ANGLE.Rool;
- RC_Yaw=(Rc_D.YAW-1500)*10;
- //-------------Yaw微分--------------------//
- Yaw_d=MPU6050_GYRO_LAST.Z-Yaw_old;
- Yaw_shell_out = Yaw_shell_kp*(MPU6050_GYRO_LAST.Z-RC_Yaw) + Yaw_shell_ki*Yaw_i + Yaw_shell_kd*Yaw_d;
- Yaw_old=MPU6050_GYRO_LAST.Z;
- ////////////////////////内环角速度环(PD)///////////////////////////////
- pitch_core_kp_out = Pitch_core_kp * (Pitch_shell_out + MPU6050_GYRO_LAST.Y * 3.5);
- pitch_core_kd_out = Pitch_core_kd * (MPU6050_GYRO_LAST.Y - Gyro_radian_old_y);
- Roll_core_kp_out = Roll_core_kp * (Roll_shell_out + MPU6050_GYRO_LAST.X *3.5);
- Roll_core_kd_out = Roll_core_kd * (MPU6050_GYRO_LAST.X - Gyro_radian_old_x);
- Yaw_core_kp_out = Yaw_core_kp * (Yaw_shell_out + MPU6050_GYRO_LAST.Z * 1);
- Yaw_core_kd_out = Yaw_core_kd * (MPU6050_GYRO_LAST.Z - Gyro_radian_old_z);
- Pitch_core_out = pitch_core_kp_out + pitch_core_kd_out;
- Roll_core_out = Roll_core_kp_out + Roll_core_kd_out;
- Yaw_core_out = Yaw_core_kp_out + Yaw_core_kd_out;
- Gyro_radian_old_y = MPU6050_GYRO_LAST.X;
- Gyro_radian_old_x = MPU6050_GYRO_LAST.Y;
- Gyro_radian_old_z = MPU6050_GYRO_LAST.Z; //储存历史值
- //--------------------将输出值融合到四个电机--------------------------------//
- if(Rc_D.THROTTLE>1020)
- thr=Rc_D.THROTTLE- 1000;
- // if(Rc_D.THROTTLE<=2000)
- // moto1=(int16_t)(thr - Pitch_core_out);//- yaw);
- // moto2=(int16_t)(thr - Pitch_core_out);//+ yaw);
- // moto3=(int16_t)(thr + Pitch_core_out);// - yaw);
- // moto4=(int16_t)(thr + Pitch_core_out);//+ yaw);
- // moto1=(int16_t)(thr - Roll_core_out);//- yaw);
- // moto2=(int16_t)(thr + Roll_core_out);//+ yaw);
- // moto3=(int16_t)(thr + Roll_core_out);// - yaw);
- // moto4=(int16_t)(thr - Roll_core_out);//+ yaw);
- // moto1=(int16_t)(thr - Yaw_core_out);//- yaw);
- // moto2=(int16_t)(thr + Yaw_core_out);//+ yaw);
- // moto3=(int16_t)(thr - Yaw_core_out);// - yaw);
- // moto4=(int16_t)(thr + Yaw_core_out);//+ yaw);
- //moto1=(int16_t)(thr - Roll_core_out - Pitch_core_out);
- //moto2=(int16_t)(thr + Roll_core_out - Pitch_core_out);
- //moto3=(int16_t)(thr + Roll_core_out + Pitch_core_out);
- //moto4=(int16_t)(thr - Roll_core_out + Pitch_core_out);
- moto1=(int16_t)(thr - Roll_core_out - Pitch_core_out- Yaw_core_out);
- moto2=(int16_t)(thr + Roll_core_out - Pitch_core_out+ Yaw_core_out);
- moto3=(int16_t)(thr + Roll_core_out + Pitch_core_out- Yaw_core_out);
- moto4=(int16_t)(thr - Roll_core_out + Pitch_core_out+ Yaw_core_out);
- else
- moto1 = 0;
- moto2 = 0;
- moto3 = 0;
- moto4 = 0;
- MOTO_PWMRFLASH(moto1,moto2,moto3,moto4);// Moto_PwmRflash(moto1,moto2,moto3,moto4);
复制代码
56
