`描述 The design is a 400-W high efficiency battery charger power supply designed to charge wide range of batteries in the voltage range of 20V to 42V and ideal for 10-Cell Li-Ion battery pack used in cordless Power Tools and Garden Tools. The design has boost PFC pre-regulator stage opearting at an efficiency of 96%. It provides high Power Factor(PF) of >0.99 and meets PFC regulation as per IEC61000-3-2 class A. The main converter stage is realised using LLC configuration and operates at an efficiency of 96% at full load. The charger is designed for input voltage range of 175V – 265V AC. The design form factor (230mm x 80mm) is compact for the power level of 400W. The design has an operating overall system efficiency of 92% at full load, with voltage and current regulation within +/- 3%. The EMI filter at the front end of the circuit is designed to meet EN55011 class A conducted emission levels. 特性 • 400 W Battery Charger with front-end PFC and half bridge LLC resonant converter • Designed to charge wide range of batteries - Li-ion, Li-poly, Ni-Cd and Lead-acid, in the voltage range of 20V to 42V • Ideal charger for 10-cell Li-ion battery pack used in industrial power tools • Delivers up to 9 A of continuous charging current for fast charging of batteries • Overall efficiency of 92% at full charging current of 9A and 230V input, eliminating need for external cooling • High power factor > 0.99 and meets PFC Regulations & Current THD as per IEC 61000-3-2 Class A • Very low standby power of < 200mW when battery is not connected • Small PCB form factor of 230 x 80 mm offers portability in usage • Provides flexibility for charge profiling through an additional external microcontroller • Charger is protected for Over current & Short-circuit at Output terminals ensuring safety needs • Meets the requirements of Conducted Emissions standard – EN55011 class A ![]() ![]() ![]() ![]() ![]() ![]() ![]() ` ![]() |
14684 浏览 0 评论
自己设计的Arduino UNO R3主控板原理图+PCB源文件(可直接打样)
14618 浏览 0 评论
73201 浏览 1 评论
3186 浏览 2 评论
7421 浏览 0 评论
基于峰岹的FU6813L波轮洗衣机控制方案(原理图+PCB+源程序
102489浏览 4评论
3190浏览 2评论
73354浏览 1评论
7426浏览 0评论
14831浏览 0评论
GMT+8, 2025-2-24 06:44 , Processed in 1.138776 second(s), Total 58, Slave 42 queries .
