36.3 对话框上使用定时器实例 这个Demo的主要功能是在对话框上面实现一个计数功能。下面是源码(可以将其直接的复制到开发板或者模拟器上面运行)
- #include
- #include "stdio.h"
- #include "GUI.h"
- #include "DIALOG.h"
- #include "WM.h"
- #include "BUTTON.h"
- #include "CHECKBOX.h"
- #include "DROPDOWN.h"
- #include "EDIT.h"
- #include "FRAMEWIN.h"
- #include "LISTBOX.h"
- #include "MULTIEDIT.h"
- #include "RADIO.h"
- #include "SLIDER.h"
- #include "TEXT.h"
- #include "PROGBAR.h"
- #include "SCROLLBAR.h"
- #include "LISTVIEW.h"
- static int Count;
- * Dialog resource
- * This table conatins the info required to create the dialog.
- * It has been created by ucGUIbuilder.
- static const GUI_WIDGET_CREATE_INFO _aDialogCreate[] = {
- { FRAMEWIN_CreateIndirect, "armfly", 0, 0, 0, 800,480,FRAMEWIN_CF_MOVEABLE,0},
- { BUTTON_CreateIndirect, "BUTTON0", GUI_ID_BUTTON0, 82, 122,162,37, 0,0},
- { BUTTON_CreateIndirect, "BUTTON1", GUI_ID_BUTTON1, 357,123,152,35, 0,0},
- { TEXT_CreateIndirect, "0000", GUI_ID_TEXT0, 278,264,300,48, 0,0}
- ** FunctionName:void PaintDialog(WM_MESSAGE * pMsg)
- ** Function: to initialize the Dialog items
- ** call this function in _cbCallback --> WM_PAINT
- void PaintDialog(WM_MESSAGE * pMsg)
- WM_HWIN hWin = pMsg->hWin;
- ** FunctionName:void InitDialog(WM_MESSAGE * pMsg)
- ** call this function in _cbCallback --> WM_INIT_DIALOG
- void InitDialog(WM_MESSAGE * pMsg)
- //FRAMEWIN
- FRAMEWIN_SetFont(hWin,&GUI_Font24B_ASCII);
- FRAMEWIN_SetTextAlign(hWin,GUI_TA_VCENTER|GUI_TA_CENTER);
- FRAMEWIN_AddCloseButton(hWin, FRAMEWIN_BUTTON_RIGHT, 0);
- FRAMEWIN_AddMaxButton(hWin, FRAMEWIN_BUTTON_RIGHT, 1);
- FRAMEWIN_AddMinButton(hWin, FRAMEWIN_BUTTON_RIGHT, 2);
- FRAMEWIN_SetTitleHeight(hWin,30);
- //GUI_ID_TEXT0
- TEXT_SetFont(WM_GetDialogItem(hWin,GUI_ID_TEXT0),&GUI_FontD36x48);
- * Dialog callback routine
- static void _cbCallback(WM_MESSAGE * pMsg)
- int NCode, Id;
- char buf[10];
- switch (pMsg->MsgId)
- case WM_TIMER:(1)
- Count++;
- sprintf(buf, "%04d", Count);
- TEXT_SetText(WM_GetDialogItem(hWin,GUI_ID_TEXT0), (const char *)buf);
- WM_RestartTimer(pMsg->Data.v, 100);
- break;
- case WM_PAINT:
- PaintDialog(pMsg);
- break;
- case WM_INIT_DIALOG:
- InitDialog(pMsg);
- break;
- case WM_KEY:
- switch (((WM_KEY_INFO*)(pMsg->Data.p))->Key)
- case GUI_KEY_ESCAPE:
- GUI_EndDialog(hWin, 1);
- break;
- case GUI_KEY_ENTER:
- GUI_EndDialog(hWin, 0);
- break;
- break;
- case WM_NOTIFY_PARENT:
- Id = WM_GetId(pMsg->hWinSrc);
- NCode = pMsg->Data.v;
- switch (Id)
- case GUI_ID_OK:
- if(NCode==WM_NOTIFICATION_RELEASED)
- break;
- case GUI_ID_CANCEL:
- break;
- case GUI_ID_BUTTON0:
- switch(NCode)
- case WM_NOTIFICATION_CLICKED:
- break;
- case WM_NOTIFICATION_RELEASED:
- break;
- case WM_NOTIFICATION_MOVED_OUT:
- break;
- break;
- case GUI_ID_BUTTON1:
- switch(NCode)
- break;
- break;
- break;
- break;
- break;
- default:
- WM_DefaultProc(pMsg);
- * MainTask
- void MainTask(void)
- WM_HWIN hDlg;
- WM_HTIMER hTimer;
- Count = 0;
- 使能窗口使用内存设备,这样可以有效避免闪烁 放在GUI_Init前面就包括桌面
- 窗口,如果放在后面就不包括桌面窗口。
- WM_SetCreateFlags(WM_CF_MEMDEV);
- GUI_Init();
- WM_SetDesktopColor(GUI_BLUE); /* Automacally update desktop window */
- PROGBAR_SetDefaultSkin(PROGBAR_SKIN_FLEX);
- FRAMEWIN_SetDefaultSkin(FRAMEWIN_SKIN_FLEX);
- BUTTON_SetDefaultSkin(BUTTON_SKIN_FLEX);
- CHECKBOX_SetDefaultSkin(CHECKBOX_SKIN_FLEX);
- DROPDOWN_SetDefaultSkin(DROPDOWN_SKIN_FLEX);
- SCROLLBAR_SetDefaultSkin(SCROLLBAR_SKIN_FLEX);
- SLIDER_SetDefaultSkin(SLIDER_SKIN_FLEX);
- HEADER_SetDefaultSkin(HEADER_SKIN_FLEX);
- RADIO_SetDefaultSkin(RADIO_SKIN_FLEX);
- ///* 创建一个对话框 */
- hDlg = GUI_CreateDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), &_cbCallback, 0, 0, 0);
- hTimer = WM_CreateTimer(WM_GetClientWindow(hDlg), 0, 100, 0);(2)
- while (1)
- GUI_Delay(500);
复制代码
1. 定时器消息,在定时器消息中实现文件控件计数值的更新。 2. 给对话框创建一个定时器,特别注意这里需要获取对话框中窗口的句柄才可以使用。 这个例子的实际显示效果如下(分辨率800*480):
