`ti 公司的bq25046 是5W(1.1A/5V)无接触充电应用的电源集成电路,适用于有线和无线电源应用,具有5V稳压输出和集成的3.3V/15mA LDO,输入电压额定值30V,15V过压保护阈值, 能给MSP430BQ1010 MCU直接供电,主要用在无线电源,智能手机,PDA,MP3播放器和低功率手持设备.本文介绍了bq25046主要特性,方框图,典型应用和无线电源系统方框图, 作无接触电源接收器的应用电路以及bqTESLA无线电源系评估套件HPA688EVM主要特性,电路图和材料清单(BOM). bq25046:1.1A, Single-Input 5-V Power Supply IC for Contactless Charging Applications The bq25046 is a highly integrated linear power supply IC targeted at both wired and wireless power applications. With an accurate 5-V regulated output and integrated 3.3-V LDO, the bq25046 is an ideal solution for wireless power supply solutions up to 5 W. The bq25046 integrates several functions which enable a wireless charging solution within a small area and low component count. These include a 3.3-V LDO which drives an MSP430BQ1010 wireless controller, high-accuracy current sense for calculating receiver-side power usage, 100mA/400mA current limits enable robust communication at all load current levels, and integrated pass FET acts as load disconnect switch and 5-V regulator to protect downstream circuitry. bq25046主要特性: 30V Input Rating, with 15V Over-Voltage Protection (OVP) Threshold Integrated Charge Current Sense for Wireless Power Transfer Efficiency Monitoring 3.3V, 15mA integrated Low Dropout Linear Regulator (VDD3.3) Supplies Power to MSP430BQ1010 Directly 2% Output Voltage Regulation Pin Selectable 100mA and 400mA Current Limit Enables Robust Communication in Wireless Power Systems at any Output Current Level Soft-Start Feature to Reduce Inrush Current Status Indication – Power Good (PG) and Output Enabled (CHG) Available in Small 2mm × 3mm DFN-10 Package bq25046应用: Wireless Power Applications Smart Phones PDAs MP3 Players Low-Power Handheld Devices 图1.bq25046方框图 图2.bq25046典型应用电路 图3.bq25046用作无接触电源接收器的应用电路 图4.无线电源系统方框图 The bqTESLA™ wireless power evaluation kit from Texas Instruments is a high-performance, easy-to-use development kit for the design of wireless power solutions. Consisting of a single-channel transmitter and direct-charge receiver and associated magnetics, the kit enables designers to speed the development of their end-applications. The bq500110EVM evaluation module (EVM) provides all basic functions of WPC 1.0-compliant wireless charger pad. The EVM is intended to be used with bq25046EVM or any other WPC 1.0-compliant receiver. This transmitter EVM is a complete transmitter-side solution that powers a bqTESLA™ receiver. The bq500110EVM requires single 19-V at 0.5 A power supply to operate and combines on the single printed-circuit board the transmitter electronics, input power socket, LED indicators, and the transmitting coil. The open design allows easy access to key points of the electrical schematic. The board has installed connectors for optional JTAG and serial interfaces that can be helpful to advanced users. 图5. bqTESLA无线电源系评估套件外形图 bqTESLA无线电源系评估套件主要特性: Single-Channel Transmitter Featuring bq500110 5V Power Supply Receiver Featuring bq25046 and MSP430bq1010 Enables Designers to Speed Development of End Applications No Additional Software Development Required Allows for True Plug-and-Play Functionality Designed for Compatibility with Qi Standard bq500110EVM-688 性能指标: |
46756 浏览 1 评论
2421 浏览 2 评论
6844 浏览 0 评论
基于峰岹的FU6813L波轮洗衣机控制方案(原理图+PCB+源程序
76344 浏览 2 评论
60675 浏览 0 评论
2424浏览 2评论
76407浏览 2评论
111947浏览 1评论
3599浏览 1评论
4850浏览 1评论
GMT+8, 2024-9-22 04:36 , Processed in 1.015040 second(s), Total 43, Slave 31 queries .
