ti 公司的bq25046 是5W(1.1A/5V)无接触充电应用的电源集成电路,适用于有线和无线电源应用,具有5V稳压输出和集成的3.3V/15mA LDO,输入电压额定值30V,15V过压保护阈值, 能给MSP430BQ1010 MCU直接供电,主要用在无线电源,智能手机,PDA,MP3播放器和低功率手持设备.本文介绍了bq25046主要特性,方框图, bq25046EVM-687评估模块主要性能指标,电路图,材料清单(BOM),测试框图和元件布局图。 bq25046:1.1A, Single-Input 5-V Power Supply IC for Contactless Charging Applications The bq25046 is a highly integrated linear power supply IC targeted at both wired and wireless power applications. With an accurate 5-V regulated output and integrated 3.3-V LDO, the bq25046 is an ideal solution for wireless power supply solutions up to 5 W. The bq25046 integrates several functions which enable a wireless charging solution within a small area and low component count. These include a 3.3-V LDO which drives an MSP430BQ1010 wireless controller, high-accuracy current sense for calculating receiver-side power usage, 100mA/400mA current limits enable robust communication at all load current levels, and integrated pass FET acts as load disconnect switch and 5-V regulator to protect downstream circuitry. bq25046主要特性: 30V Input Rating, with 15V Over-Voltage Protection (OVP) Threshold Integrated Charge Current Sense for Wireless Power Transfer Efficiency Monitoring 3.3V, 15mA integrated Low Dropout Linear Regulator (VDD3.3) Supplies Power to MSP430BQ1010 Directly 2% Output Voltage Regulation Pin Selectable 100mA and 400mA Current Limit Enables Robust Communication in Wireless Power Systems at any Output Current Level Soft-Start Feature to Reduce Inrush Current Status Indication – Power Good (PG) and Output Enabled (CHG) Available in Small 2mm × 3mm DFN-10 Package bq25046应用: Wireless Power Applications Smart Phones PDAs MP3 Players Low-Power Handheld Devices 图1.bq25046方框图 bq25046EVM-687评估模块 The bq25046EVM-687 evaluation module (EVM) demonstrates the receiver portion of the bqTESLA™ wireless power system. This receiver EVM is a complete receiver-side solution that produces 5 V out at up to 1 A when coupled with the bqTESLA™ transmitter. Two key bqTESLA™ devices are shown on this EVM, the bq25046 and MSP430bq1010, and external components that support the two devices for a complete solution. • The bqTESLA™ receiver can be used in any number of low-power battery portable devices as a power source for charging. With contact-free charging capability, no connections to the device are needed. • Output voltage of 5 V up to 1 A • External adapter switchover and control circuit • Low-profile, external pick-up coil • Frame is configured to provide correct receiver to transmitter spacing. • Room above coil for testing with battery, key for tuning bq25046EVM-687评估模块主要性能指标: |
41955 浏览 1 评论
2222 浏览 2 评论
6712 浏览 0 评论
基于峰岹的FU6813L波轮洗衣机控制方案(原理图+PCB+源程序
71520 浏览 2 评论
60553 浏览 0 评论
2223浏览 2评论
71608浏览 2评论
3305浏览 1评论
开源#具有变速控制的 5V、三相无传感器正弦电机系统设计方案
5646浏览 1评论
180756浏览 1评论
GMT+8, 2024-8-24 09:05 , Processed in 1.087871 second(s), Total 58, Slave 43 queries .
