电子发烧友论坛|
`ti公司的bq500412是无线充电联盟(WPC)标准WPC 1.1 Qi兼容的无线充电发送器,集成了控制无线充电的所有功能,设计用于12V充电系统或5V充电系统,可以对智能手机等进行智能充电.本文介绍了bq500412主要特性,框图, 系统框图以及bq500412EVM-584 评估模块主要特性和性能指标,电路图,材料清单和PCB元件布局图. The bq500412 is a Qi-certified value solution that integrates all functions required to control wireless power delivery to a single WPC1.1 compliant receiver. It is WPC1.1 compliant and designed for 12-V systems, or 5-V systems with an optional boost converter, as a wireless power consortium type A6 free positioning transmitter. The bq500412 the surrounding environment for WPC compliant devices to be powered, safely engages the device, receives packet communication from the powered device and manages the power transfer according to WPC1.1 specification. To maximize flexibility in wireless power control applications, Dynamic Power Limiting (DPL) is featured on the bq500412 when used with an optional boost converter from a 5-V input. Dynamic Power Limiting enhances user experience by seamlessly optimizing the usage of power available from limited input supplies. The bq500412 supports both Foreign Object Detection (FOD) and enhanced Parasitic Metal Object Detection (PMOD) for legacy product by continuously monitoring the efficiency of the established power transfer, protecting from power lost due to metal objects misplaced in the wireless power transfer field. Should an abnormal operating condition develop during power transfer, the bq500412 handles it and provides indicator outputs. Comprehensive status and fault monitoring features enable a low cost yet robust, Qi-certified wireless power system design. The bq500412 is available in a 48-pin, 7-mm x 7-mm QFN package. bq500412主要特性: Proven, Qi-Certified WPC1.1 Solution for Transmit-Side Application (suitable for 1, 2 or 3 coil configurations) Lowest Device Count for Full WPC1.1 12-V A6 Solution (single driver stage for all coils) New Standby Scheme Reduces Standby and Sleep Power Without Need for Extra Supervisor Circuit Improved FOD Calibration Scheme Simplifies Certification and Increases Accuracy at Higher Power (customer configurable) Dynamic Power Limiting™ for USB and Limited Power Source Operation When Used With 5-V Input Digital Demodulation Removes Need for External Filter Circuitry 10 Configurable LED modes Indicate Charging State and Fault Status bq500412应用: • Wireless Power Consortium (WPC1.1) Compliant Wireless Chargers For: – Qi-Certified Smart Phones and Other Handhelds – Car and Other Vehicle Accessories
图1. bq500412框图
图2. bq500412系统框图 bq500412 bqTESLA无线电源 TX EVM The bqTESLA™ wireless power transmitter evaluation module from Texas Instruments is a highperformance, easy-to-use development module for the design of wireless power solutions. The bq500412 EVM evaluation module (EVM) provides all the basic functions of a Qi-compliant three coil, A6 type, wireless charger pad. The EVM is intended to be used with bq51013BEVM-764 or any other Qi-compliant receiver. Both the WPC 1.0 and WPC 1.1 receivers are supported with this design. The bq500412EVM-584 is a 12-V input design with an optional boost convert for operation from 5-V input. The bq500412EVM-584 evaluation module demonstrates the transmitter portion of the bqTESLA™ wireless power system. This transmitter EVM is a complete transmitter-side solution that powers a bqTESLA™ receiver. The EVM requires only input power for operation, 12 V at 1 A or 5 V at 2.5 A. All transmitter-side electronics and transmitter coils are on a single 4-layer printed-circuit board (PCB). The open design allows easy access to key points of the electrical schematic. 图3.bq500412EVM-584无线电源发送管理评估模块外形图 Free Positioning, Qi-Compliant Wireless Power Transmitter Manager Evaluation Module bq500412EVM-584 评估模块性能指标:
bq500412EVM-584 评估模块主特性: • WPC A6-Type transmitter coil, 70 mm × 25 mm free positioning area • Input voltage 12 V or 5 V, using optional boost converter • WPC 1.1 Foreign Object Detection (FOD) and WPC 1.0 Parasitic Metal Object Detection (PMOD) • Dynamic Power Limiting™ (DPL) allows operation from a 5-V supply with limited current capability (for example, a USB port) • Reduced parts count from the legacy bq500410A design • Compact power section design using the CSD97374 NexFET power stage • LED indicates power transfer or power fault state
图4. bq500412EVM-584 评估模块电路图 bq500412EVM-584 评估模块材料清单:
图5. bq500412EVM-584 评估模块PCB元件布局图:顶层
slvu987.pdf
(914.12 KB, 下载次数: 3
bq500412.pdf
(918.55 KB, 下载次数: 4
3361 浏览 0 评论
自己设计的Arduino UNO R3主控板原理图+PCB源文件(可直接打样)
3342 浏览 0 评论
61828 浏览 1 评论
2817 浏览 2 评论
7116 浏览 0 评论
基于峰岹的FU6813L波轮洗衣机控制方案(原理图+PCB+源程序
91442浏览 4评论
2820浏览 2评论
5128浏览 1评论
61925浏览 1评论
7119浏览 0评论
GMT+8, 2024-12-23 12:51 , Processed in 1.096601 second(s), Total 54, Slave 40 queries .
