扫一扫,分享给好友
STC12C5A60S2输出PWM后怎么在程序中调节占空比?????例如中断中怎么赋值能改变输出PWM的占空比???? |
9个回答
以前用过STC其它型号的做过PWM,也可以调节占空比,你仔细看手册,里面很详细的。
规格书上有对应的寄存器,一个是设置Pwm的频率,一个是设置占空比,你要调频的话改变设置占空比的寄存器就可以了
手册中只有输出固定占空比的例程,我改调节占空比的参数结果占空比还是没有变化
#include "reg51.h" #include "intrins.h" #define FOSC 18432000L typedef unsigned char BYTE; typedef unsigned int WORD; /*Declare SFR associated with the PCA */ sfr CCON = 0xD8; //PCA control register ***it CCF0 = CCON^0; //PCA module-0 interrupt flag ***it CCF1 = CCON^1; //PCA module-1 interrupt flag ***it CR = CCON^6; //PCA timer run control bit ***it CF = CCON^7; //PCA timer overflow flag sfr CMOD = 0xD9; //PCA mode register sfr CL = 0xE9; //PCA base timer LOW sfr CH = 0xF9; //PCA base timer HIGH sfr CCAPM0 = 0xDA; //PCA module-0 mode register sfr CCAP0L = 0xEA; //PCA module-0 capture register LOW sfr CCAP0H = 0xFA; //PCA module-0 capture register HIGH sfr CCAPM1 = 0xDB; //PCA module-1 mode register sfr CCAP1L = 0xEB; //PCA module-1 capture register LOW sfr CCAP1H = 0xFB; //PCA module-1 capture register HIGH sfr PCAPWM0 = 0xf2; sfr PCAPWM1 = 0xf3; ***it k=P1^0; BYTE a=0; void main() { CCON = 0; //Initial PCA control register //PCA timer stop running //Clear CF flag //Clear all module interrupt flag CL = 0; //Reset PCA base timer CH = 0; CMOD = 0x02; //Set PCA timer clock source as Fosc/2 //Disable PCA timer overflow interrupt CCAP0H = CCAP0L =a; //PWM0 port output 50% duty cycle square wave CCAPM0 = 0x42; //PCA module-0 work in 8-bit PWM mode PCAPWM0 = 0x03; //and no PCA interrupt CCAP1H = CCAP1L = 255; //PWM1 port output 0% duty cycle square wave PCAPWM1 = 0x03; CCAPM1 = 0x42; //PCA module-1 work in 8-bit PWM mode and no PCA interrupt CR = 1; //PCA timer start run EA=1; EX0=1; while(1); } void inter0() interrupt 0 { a=200; } 这是把手册上例程修改过的程序,通过中断修改a的值从而使100%的占空比变为(256-200)/256的占空比,但是达不到预期的要求,求大神指点。。。。。。。。。。 |
计时器控制高低电平随便来啊
谢谢。。。。。。。。。。。。。。。。。。我试试程序
CCAP0H=CCAP0L这两个是什么关系?
去掉PCAPWM0 = 0x30; |
998 浏览 0 评论
esp8266作为tcp客户端,服务器主动断开连接后,是会主动重连吗,如何设置不要主动重连呢
1786 浏览 1 评论
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-platform总线驱动简单示例
679 浏览 0 评论
《DNESP32S3使用指南-IDF版_V1.6》第六十章 猫脸检测实验
1031 浏览 2 评论
1311 浏览 2 评论
12792 浏览 31 评论
GMT+8, 2025-4-9 11:41 , Processed in 0.614708 second(s), Total 57, Slave 50 queries .
