描述及特性 The design implements a TPS40210. The TPS40210 and TPS40211 are wide-input voltage (4.5 V to 52 V), non-synchronous boost controllers. They are suitable for topologies which require a grounded source N-channel FET including boost, flyback, SEPIC and various LED Driver applications. The device features include programmable soft start, overcurrent protection with automatic retry and programmable oscillator frequency. Current mode control provides improved transient response and simplified loop compensation. The main difference between the two parts is the reference voltage to which the error amplifier regulates the FB pin. ![]() ![]() ![]() ![]() |
14684 浏览 0 评论
自己设计的Arduino UNO R3主控板原理图+PCB源文件(可直接打样)
14618 浏览 0 评论
73201 浏览 1 评论
3186 浏览 2 评论
7421 浏览 0 评论
基于峰岹的FU6813L波轮洗衣机控制方案(原理图+PCB+源程序
102504浏览 4评论
3190浏览 2评论
73372浏览 1评论
7426浏览 0评论
14846浏览 0评论
GMT+8, 2025-2-24 08:17 , Processed in 1.016451 second(s), Total 54, Slave 40 queries .
