请问定时器时钟分频是否只与这里的配置有关,应该没有其他相关了。以下是程序,keil的debug里观察P1波形,变动频率却是1HZ,用的是C8051F310晶振24.5MHZ。配置为系统时钟的48分频,可实际为系统时钟32分频,求解!谢谢各位大神! ORG 0000H LJMP MAIN ORG 000BH ;定时器T0中断入口 LJMP IT0P ORG 0200H MAIN: LCALL Init_Device ;设备初始化 MOV SP, #60H ;置堆栈指针 MOV TMOD,#01H ;确定工作方式 SETB EA ;允许中断 SETB ET0 LOOP2: MOV TH0,#06H MOV TL0,#0C6H MOV R0, #0 CLR A LOOP: SETB TR0 CJNE A, #8EH, LOOP MOV P1, A CLR TR0 SJMP LOOP2 IT0P: MOV TH0,#06H MOV TL0,#0C6H CLR P0.7 ;选择数码管最末位管 CLR P0.6 CLR A MOV A, R0 MOV DPTR, #TABLE MOVC A, @A+DPTR MOV P1, A INC R0 REti ORG 0040H TABLE: DB 0FCH,60H,0DAH,0F2H,66H,0B6H DB 0BEH,0E0H,0FEH,0F6H,0EEH,0FEH DB 9CH,0FCH,9EH,8EH ;------------------------------------ ;- Generated Initialization File -- ;------------------------------------ $include (C8051F310.inc) public Init_Device INIT SEGMENT CODE rseg INIT ; Peripheral specific initialization functions, ; Called from the Init_Device label PCA_Init: anl PCA0MD, #0BFh mov PCA0MD, #000h ret Timer_Init: mov TMOD, #001h mov CKCON, #002h ret Port_IO_Init: mov XBR1, #040h ret Interrupts_Init: mov IT01CF, #021h ret ; Initialization function for device, ; Call Init_Device from your main program Init_Device: lcall PCA_Init lcall Timer_Init lcall Port_IO_Init lcall Interrupts_Init ret end用CONFIG2配置的 ![]() |
谢谢各位大神,困扰我很久了!谢谢,谢谢
ULink2 和keil4 连接显示 SWD通讯失败,硬件在另一台电脑上是可以连接成功的,有没有大佬能帮忙解答一下的
1663 浏览 0 评论
2235 浏览 1 评论
1004 浏览 0 评论
1026 浏览 0 评论
QuarkPi-CA2 RK3588S卡片电脑:6.0Tops NPU+8K视频编解码+接口丰富,高性能嵌入式开发!
2167 浏览 0 评论
12935 浏览 31 评论
GMT+8, 2025-4-23 18:15 , Processed in 0.529134 second(s), Total 72, Slave 54 queries .
