`描述及特性 This supply uses the TPS54160 buck regulator to generate a 5V/0.5A regulated output and an auxilliary 5V/0.2A unregulated output. A two winding coupled inductor is used to generate the auxilliary output. The auxilliary output is left floating, and could be used as a -5V output or as a second +5V output. This simple design results in an efficient, yet low cost solution for a dual output system. The peak efficiency is over 88%.
PMP9091 Test Results.pdf
(1.46 MB, 下载次数: 2
PMP9091 BOM.pdf
(78.29 KB, 下载次数: 1
PMP9091 Gerber.zip
(175.47 KB, 下载次数: 4
PMP9091 PCB.pdf
(156.75 KB, 下载次数: 1
PMP9091 Schematic.pdf
(104.21 KB, 下载次数: 1
55201 浏览 1 评论
2662 浏览 2 评论
7017 浏览 0 评论
60849 浏览 0 评论
180892 浏览 1 评论
基于峰岹的FU6813L波轮洗衣机控制方案(原理图+PCB+源程序
84765浏览 4评论
2662浏览 2评论
120156浏览 1评论
3751浏览 1评论
5016浏览 1评论
GMT+8, 2024-11-15 07:00 , Processed in 0.998142 second(s), Total 40, Slave 31 queries .
