`描述及特性 This reference design provides an isolated 5V/2A output from a universal 85-265VAC input. This design uses the UCC28710 PWM controller with primary-side regulation (PSR) eliminating the need for an optocoupler and saving cost. Maximum load efficiency is over 82%. The UCC28710 also provides accurate current limiting which eliminates the need for a load protecting switch on the output. ![]() ![]() ![]() ![]() ![]() ` ![]() |
16680 浏览 0 评论
自己设计的Arduino UNO R3主控板原理图+PCB源文件(可直接打样)
16365 浏览 0 评论
75041 浏览 1 评论
3239 浏览 2 评论
7470 浏览 0 评论
基于峰岹的FU6813L波轮洗衣机控制方案(原理图+PCB+源程序
104149浏览 4评论
3243浏览 2评论
75111浏览 1评论
7472浏览 0评论
16750浏览 0评论
GMT+8, 2025-3-5 04:50 , Processed in 0.786666 second(s), Total 39, Slave 30 queries .
