我想把中断产生的秒数实时写进AT24C02以实现掉电存储,程序如下,烧录后发现,复位之后数码管依然从初始数据开始跑,试了很多次都找不到问题在哪....求高手帮忙看下
#include #define uchar unsigned char #define uint unsigned int unsigned char code aa[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77}; uchar sec,num=0; bit write=0; ***it dula=P2^6; ***it wela=P2^7; ***it clock=P2^1; ***it date=P2^0; void delay() {;;} void delayms(int num) { int x,y; for(x=num;x>0;x--) for(y=112;y>0;y--); } void start() { date=1; delay(); clock=1; delay(); date=0; delay(); } void stop() { date=0; delay(); clock=1; delay(); date=1; delay(); } void init() { clock=1; delay(); date=1; delay(); } void response() { char i; clock=1; delay(); while((date==1)&&(i<255)) i++; clock=0; delay(); } void write_byte(unsigned char date) { uchar i,temp; temp=date; for(i=0;i<8;i++) { temp=temp<<1; clock=0; delay(); date=CY; delay(); clock=1; delay(); } clock=0; delay(); date=1; delay(); } uchar read_byte() { char k=0,i; clock=0; delay(); date=1; delay(); for(i=0;i<8;i++) { clock=1; delay(); k=(k<<1)|date; clock=0; delay(); } return k; } void write_add(uchar address,uchar date) { EA=0; start(); write_byte(0xa0); response(); write_byte(address); response(); write_byte(date); response(); stop(); EA=1; delayms(5); } uchar read_add(uchar address) { uchar date; start(); write_byte(0xa0); response(); write_byte(address); response(); start(); write_byte(0xa1); response(); date=read_byte(); stop(); return date; } void display(int a,int b) { dula=1; P0=aa[a]; dula=0; P0=0xff; wela=1; P0=0xfe; wela=0; delayms(2); dula=1; P0=aa[b]; dula=0; P0=0xff; wela=1; P0=0xfd; wela=0; delayms(2); } void main() { unsigned char i; TMOD=0x01; EA=1; ET0=1; TR0=1; init(); sec=read_add(2); TH0=(65536-45872)/256; TL0=(65536-45872)%256; TR0=1; while(1) { i=10; while(i--) //避免数码管闪烁 { display(sec/10,sec%10); } if(write==1) { write=0; write_add(2,sec); } } } void time0() interrupt 1 using 0 { TH0=(65536-45872)/256; TL0=(65536-45872)%256; num++; if(num==20) { num=0; sec++; write=1; if(sec>=100) sec=0; } } |
能不能发下烧录软件的显示情况,不一定是程序的问题
524 浏览 0 评论
321 浏览 0 评论
零知开源——基于STM32F407VET6零知增强板的四路独立计时器
1827 浏览 0 评论
零知开源——STM32F4实现ILI9486显示屏UI界面系列教程(一):电子书阅读器功能
1805 浏览 0 评论
CW32L010 ESC Driver 电机控制套件快速上手指南
1277 浏览 1 评论
13734 浏览 31 评论
GMT+8, 2025-7-16 06:05 , Processed in 0.382186 second(s), Total 39, Slave 33 queries .
