`描述 This is an incremental rotary encoder that uses contactless magnetic sensing to detect rotational speed and direction. The two Hall Effect sensors measure the 66-pole ring magnet and output two signals in quadrature. This automotive-qualified solution is a low-cost and far more reliable alternative to conventional mechanical contact-based encoders, as it uses solid-state sensing that is immune to physical wear, dirt, corrosion, and RF noise. 特性
14518 浏览 0 评论
自己设计的Arduino UNO R3主控板原理图+PCB源文件(可直接打样)
14442 浏览 0 评论
73020 浏览 1 评论
3183 浏览 2 评论
7418 浏览 0 评论
基于峰岹的FU6813L波轮洗衣机控制方案(原理图+PCB+源程序
102291浏览 4评论
3185浏览 2评论
73139浏览 1评论
7419浏览 0评论
14628浏览 0评论
GMT+8, 2025-2-23 05:22 , Processed in 1.258673 second(s), Total 54, Slave 39 queries .
