`描述 This TPS65218-based reference design is a compact, integrated power solution for Xilinx® Zynq® 7010 SoC/FPGAs (out of the Zynq® 7000 series family of products). This design showcases TPS65218 as an all-in-one PMIC used to supply the five rails needed for powering the Zynq® 7010 SoC/FPGAs. The total board area needed for TPS65218, including passive components, to supply the five power rails to the Zynq® 7010 is just 1.594 in2. The TPS65218 has the flexibility to support either DDR3L or DDR3 memory. This power management IC can be run from a single 5V supply or from a single cell Li-Ion battery. This design is guaranteed to operate across an industrial temperature range (-40°C to 105°C). 特性
tidrd19.zip
(1.23 MB, 下载次数: 3
TPS65218EVM User's Guide.pdf
(6.9 MB, 下载次数: 2
TIDA-00478 BOM.pdf
(110.55 KB, 下载次数: 2
TIDA-00478 Schematic and Block Diagram.pdf
(211.2 KB, 下载次数: 2
TIDA-00478 Test Results.pdf
(1.44 MB, 下载次数: 2
46663 浏览 1 评论
2421 浏览 2 评论
6843 浏览 0 评论
基于峰岹的FU6813L波轮洗衣机控制方案(原理图+PCB+源程序
76249 浏览 2 评论
60675 浏览 0 评论
2421浏览 2评论
76318浏览 2评论
111855浏览 1评论
3597浏览 1评论
4847浏览 1评论
GMT+8, 2024-9-21 14:39 , Processed in 1.074265 second(s), Total 52, Slave 38 queries .
