LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL; USE IEEE.STD_LOGIC_UNSIGNED.ALL; USE IEEE.STD_LOGIC_ARITH.ALL; ENtiTY EVEN_DIVIDER IS GENERIC(N:INTEGER :=8); PORT( CLKIN: IN STD_LOGIC; CLKOUT:OUT STD_LOGIC; CNT:OUT STD_LOGIC_VECTOR(2 DOWNTO 0) ); END EVEN_DIVIDER; ARCHITECTURE RTL OF EVEN_DIVIDER IS SIGNAL COUNT:INTEGER; BEGIN 该程序实现8分频,送入输入时钟,输出时钟恒为’1‘,请问为何 |
3个回答
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL; USE IEEE.STD_LOGIC_UNSIGNED.ALL; USE IEEE.STD_LOGIC_ARITH.ALL; ENTITY EVEN_DIVIDER IS GENERIC(N:INTEGER :=8); PORT( CLKIN: IN STD_LOGIC; CLKOUT:OUT STD_LOGIC; CNT:OUT STD_LOGIC_VECTOR(2 DOWNTO 0) ); END EVEN_DIVIDER; ARCHITECTURE RTL OF EVEN_DIVIDER IS SIGNAL COUNT:INTEGER; BEGIN PROCESS (CLKIN) BEGIN IF CLKIN'EVENT AND CLKIN='1' THEN IF COUNT=N-1 THEN COUNT<=0; ELSE COUNT<=COUNT+1; IF COUNT ELSE CLKOUT<='0'; END IF; END IF; END IF; END PROCESS; CNT<=CONV_STD_LOGIC_VECTOR(COUNT,3); END RTL; 上面程序粘掉了 |
IF COUNT=N-1 THEN
COUNT<=0; ELSE COUNT<=COUNT+1; END IF; IF COUNT ELSE CLKOUT<='0'; END IF; 改成这样 |
AG32软件包SDK更新:加入新例程(可实现至少15个UART串口)
1023 浏览 0 评论
从零开始驯服Linux(一):ZYNQ-Linux启动文件构建全解析
1822 浏览 0 评论
AG32 SDK 更新版本1.7.0:加入dsp例程和Slave SPI例程
626 浏览 0 评论
1241 浏览 0 评论
595 浏览 0 评论
6489 浏览 114 评论
2589 浏览 58 评论
GMT+8, 2025-3-31 07:17 , Processed in 0.496179 second(s), Total 40, Slave 35 queries .
