STM32结合AD1256进行调试,始终不能出正常结果,不知道有没有大神调过,能否帮我看下程序,我可能没有分数,初来这个论坛,还望大神给予指导。
示波器显示波形也正确,无论模拟输入多少,输出变量值始终为0x10453附近变动,请教各位大神,有了解的吗? 以下是程序: int main(void) { // unsigned long results = 0; unsigned char i = 0; SystemInit(); //时钟初始化 delay_init(72); //延迟初始化 SPI_ADS1256_Init(); //SPI初始化 ADS1256_GPIO_init(); //与AD相关GPIO初始化 ADS1256_Init();//AD1256初始化 while(1) { results = ADS1256ReadData(); } 以下SPI_ADS1256_Init()----------------------------------- void SPI_ADS1256_Init(void) { SPI_InitTypeDef SPI_InitStructure; GPIO_InitTypeDef GPIO_InitStructure; /* Enable SPI1 and GPIO clocks */ /*!< SPI_FLASH_SPI_CS_GPIO, SPI_FLASH_SPI_MOSI_GPIO, SPI_FLASH_SPI_MISO_GPIO, SPI_FLASH_SPI_DETECT_GPIO and SPI_FLASH_SPI_SCK_GPIO Periph clock enable */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOD, ENABLE); /*!< SPI_FLASH_SPI Periph clock enable */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE); /*!< AFIO Periph clock enable */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE); /*!< Configure SPI_FLASH_SPI pins: SCK */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5; // // GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; // ÍÆÃâÊä³ö GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; // ¸´ÓÃÍÆÃâÊä³ö GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz; GPIO_Init(GPIOA, &GPIO_InitStructure); /*!< Configure SPI_FLASH_SPI pins: DIN */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7; // GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; // ¸´ÓÃÍÆÃâÊä³ö GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz; GPIO_Init(GPIOA, &GPIO_InitStructure); /*!< Configure SPI_FLASH_SPI pins: DOUT */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6; // GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; //ÉÏÀÊäÈë // GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; // ¸´ÓÃÍÆÃâÊä³ö GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz; GPIO_Init(GPIOA, &GPIO_InitStructure); SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex SPI_InitStructure.SPI_Mode = SPI_Mode_Master; SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b; SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low; SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge; // SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; //´ SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_64; SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; //Êý¾Ý´«Êä´ÓMSBλ¿ªÊ¼ SPI_InitStructure.SPI_CRCPolynomial = 7; //CRCÖµ¼ÆËãµÄ¶àÏîʽ SPI_Init(SPI1, &SPI_InitStructure); /* Enable SPI1 */ SPI_Cmd(SPI1, ENABLE); } void ADS1256_GPIO_init(void) { GPIO_InitTypeDef GPIO_InitStructure; /////////CS reset Òý½ÅÉèÖà RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); GPIO_InitStructure.GPIO_Pin= GPIO_Pin_4 | GPIO_Pin_12; GPIO_InitStructure.GPIO_Mode= GPIO_Mode_Out_PP; //--ÍÆÃâÊä³öģʽ //GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_InitStructure.GPIO_Speed= GPIO_Speed_10MHz; //--GPIO·×ªËÙ¶ÈΪ50MHz GPIO_Init(GPIOA , &GPIO_InitStructure); //--½«ÅäÖÃдÈë¶ÔÓ¦µÄGPIO¼Ä´æÆ÷ÖÐ // GPIO_InitTypeDef GPIO_InitStructure; ///////// DRDYÒý½ÅÉèÖà RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); GPIO_InitStructure.GPIO_Pin= GPIO_Pin_2; GPIO_InitStructure.GPIO_Mode= GPIO_Mode_IN_FLOATING; //--¸¡µãÊäÈëģʽ GPIO_InitStructure.GPIO_Speed= GPIO_Speed_10MHz; //--GPIO·×ªËÙ¶ÈΪ50MHz GPIO_Init(GPIOA , &GPIO_InitStructure); //--½«ÅäÖÃдÈë¶ÔÓ¦µÄGPIO¼Ä´æÆ÷ÖÐ GPIO_Init(GPIOA , &GPIO_InitStructure); //--½«ÅäÖÃдÈë¶ÔÓ¦µÄGPIO¼Ä´æÆ÷ÖÐ } void ADS1256_Init(void) { ADS_CS_LOW(); RESET_HIGH(); delay_us(100); SPI_SendByte(ADS1256_CMD_REST); delay_ms(10); while(ADS_DRDY); //µ±ADS1256_DRDYΪµÍʱ²ÅÄÜд¼Ä´æÆ÷ SPI_SendByte(ADS1256_CMD_SYNC); //ͬ²½ÃüÁî SPI_SendByte(ADS1256_CMD_WAKEUP); //ͬ²½»½ÐÑ while(ADS_DRDY); SPI_SendByte(ADS1256_CMD_WREG | ADS1256_STATUS);//Á¬ÐøдÈë4¸ö¼Ä´æÆ÷ SPI_SendByte(3); SPI_SendByte(0x04); //¸ßλÔÚÇ°£¬Ê¹ÓÃÄÚ²¿Ð£×¼£¬²»Ê¹Óûº´æ SPI_SendByte(ADS1256_MUXP_AIN2 | ADS1256_MUXN_AIN3);//¶Ë¿ÚÊäÈëA2ΪÕý£¬A3λ¸º SPI_SendByte(ADS1256_GAIN_1); //·Å´ó±¶ÊýÉèÖà SPI_SendByte(ADS1256_DRATE_2_5SPS); //²É¼¯ËÙ¶ÈÉèÖà delay_us(100); while(ADS_DRDY); //µ±ADS1256_DRDYΪµÍʱ²ÅÄÜд¼Ä´æÆ÷ SPI_SendByte(ADS1256_CMD_SELFCAL); //Æ«ÒƺÍÔöÒæ×Ô¶¯Ð£×¼ ADS_CS_HIGH(); delay_ms(100); } unsigned long ADS1256ReadData(void) { unsigned char i=0; unsigned long sum=0; unsigned long r=0; ADS_CS_LOW(); while(ADS_DRDY); //µ±ADS1256_DRDYΪµÍʱ²ÅÄÜд¼Ä´æÆ÷ SPI_SendByte(ADS1256_CMD_SYNC); SPI_SendByte(ADS1256_CMD_WAKEUP); SPI_SendByte(ADS1256_CMD_RDATA); delay_us(10); //min=50*(1/fCLKIN)=50*(1/7.68MHZ)=6500ns;max=whatever for(i=0;i<3;i++) { sum = sum << 8; r = SPI_SendByte(0); sum |= r; } ADS_CS_HIGH(); return sum; } |
首先确定硬件连接,STM32的SPI模块通信测试程序通过没有,STM32管脚的初始化和时钟的配置……一般这个都没错
然后是AD1256器件的配置啦,必须要读手册,确认每个寄存器的配置位是否正确 用到的delay函数应该是systic写的吧, 我觉得主要还是器件的操作问题~~~ |
检查通信的时序是不是与手册里面要求的一致,该延时的地方有没有延时。
《DNK210使用指南 -CanMV版 V1.0》第八章 CanMV IDE初体验
1680 浏览 0 评论
过采样提高12位ADC精度在STM32主控上的实现(附电路及代码)
1145 浏览 1 评论
飞凌嵌入式-ELFBOARD 解决PCB布线时无法捕捉到焊盘中心的问题
1104 浏览 0 评论
Openharmony软件评估指南-米尔瑞芯微RK3568开发板
1965 浏览 0 评论
STM32CUBEMX(7)--移植雅特力AT32F403AVGT(兼容STM32F103VGT6),DAC输出电压
1385 浏览 0 评论
11188 浏览 31 评论
GMT+8, 2024-9-21 15:47 , Processed in 0.597602 second(s), Total 72, Slave 56 queries .
