扫一扫,分享给好友
initial是不可综合语句
首先按键信号复位后无论按没按下,流水灯都应该动作,那么是你时钟或者复位信号没输进去吧,查查板子的IO口和你定义的UCF文件。其次你的按键处理应该是下降沿转脉冲,但是你的流水灯判断却是电平敏感,直接用IO信号或者作缓冲吧,按键IO配置上拉!
没看到东西啊!
always @ (*)
begin if(TIME_CNT == 24'h0 ) begin if(PUSH_SW1==1'b1) LED_DATA_N = {LED_DATA[5],LED_DATA[4:0]}; else LED_DATA_N = {LED_DATA[4:0],LED_DATA[5]}; end else LED_DATA_N = LED_DATA; end endmodule |
各位大侠 PUSH_SW1是拨码开关,我想的是拨码开关为高电平时正向流动,为低电平时反向流动,可现在是低电平能正常流动,高电平时停止不动啊 |
always @(negedge RST_B or negedge SYSCLK_50M)
begin if(!RST_B) TIME_CNT <= `UD 21'b0; else TIME_CNT <= `UD TIME_CNT_N; end assign TIME_CNT_N = TIME_CNT + 21'b1; always @(negedge RST_B or negedge SYSCLK_50M) begin if(!RST_B) LED_DATA <= `UD 6'b11_1110;//这里LED同样是低电平有效,初值只允许一个LED亮 else LED_DATA <= `UD LED_DATA_N; end |
module WATER_LIGHTS
( //Input ports. SYSCLK_50M, RST_B, PUSH_SW1, //Output ports. LED_DATA ); //=========================================================================== //Input and output declaration //=========================================================================== input SYSCLK_50M; //System clock, 50MHz. input RST_B; //Global reset, low active. input PUSH_SW1; //G //input key; //G output [5:0] LED_DATA; //LED data output. //=========================================================================== //Wire and reg declaration //=========================================================================== wire SYSCLK_50M; wire RST_B; reg [5:0] LED_DATA; wire PUSH_SW1; //wire key; //=========================================================================== //Wire and reg in the module //=========================================================================== reg [23:0] TIME_CNT; //Count the time, everyone show 1ms. reg [5:0] LED_DATA_N; //Next value of LED_DATA. wire [23:0] TIME_CNT_N; //Next value of TIME_CNT. |
完整代码,哪位大侠指点下谢谢
双目视觉处理系统开发实例-基于米尔安路国产DR1M90开发板
1075 浏览 0 评论
1545 浏览 0 评论
基本FPGA或者树莓派或者其它微处理器(尽量压缩成本且完成项目)DFB激光器稳频
2083 浏览 1 评论
3190 浏览 1 评论
助力AIoT应用:在米尔FPGA开发板上实现Tiny YOLO V4
1316 浏览 0 评论
2463 浏览 58 评论
6269 浏览 113 评论
GMT+8, 2025-2-25 10:49 , Processed in 0.805798 second(s), Total 89, Slave 71 queries .
