DS-5 v5.14 Linux 64bit 官方开发工具 - 软件 - 电子威廉希尔官方网站 论坛 - 最好最受欢迎电子论坛!
百度网盘:http://pan.baidu.com/s/1dDgXwgp
说明:
(1)点此查看DS-5详细说明
(2)该版本为官方评估版本,安装许可证(包括试用许可证后可以使用全部功能
(3)自DS-5 v5.14版本起,不用通过ARM网站即可申请30天试用许可证,直接使用DS-5软件本地生成试用许可证,即可评估DS-5软件30天,参见介绍:http://www.myir-tech.com/resource/454.asp
(4)该版本是从ARM官方网站下载而来,为方便国内用户提供的下载地址,并非DS-5破解版。
(5)该版本可安装在Linux 64位系统上。
这是在此版本中的新功能和其他重要事项变更的摘要:
DS-5 version 5.14 (build 1702 2013/03/26)
This is a summary of the new features and other major changes in this release:
    ARM CompilerARM Streamline Performance Analyzer
    • new live view added to show performance data as it is being captured
    • Timeline view displays individual kernel threads under the kernel process
    • Timeline view allows easy restoration of auto-generated charts via the snippets menu
    • includes gator version 13
    • gator adds support for monitoring the performance of CoreLink CCI-400 (Cache Coherent Interconnect)
    • gator adds support for environmental data such as temperature, voltage, power and energy within the Linux kernel via the hwmon interface
    • gator adds support for capturing counters from clusters independently in a big.LITTLE system
    DS-5 Debugger
    • added OS awareness for Keil CMSIS-RTOS RTX on Cortex-M and Cortex-A9 devices
    • added OS awareness for Freescale MQX RTOS on ARM processor-based Freescale devices
    • trace displays can be time-correlated within the debugger and with external tools
    • support is provided for displaying the CoreSight Global Timestamp unit
    • instruction and data trace from ETMv4 devices (such as Cortex-R7) is now supported
    • Altera USB-Blaster is supported as a connection mechanism to Altera Arria V SoC and Cyclone V SoC boards
    • context menu in the Debug Control and Trace views allows editing DTSL (Debug and Trace Services Layer) options during a debug session
    • new command set/show dtsl-options can be used to access DTSL options during a debug session
    • new command set/show trust-ro-sections-for-opcodes controls whether trace and disassembly can rely on data from read-only sections within any images that are loaded
    • device support extended to include: Altera Arria V SoC, Altera Cyclone V SoC and Atmel ATSAMA5D3x
    DSTREAM/RVI
    • new 4.11.0 version of firmware included
    • Cortex-A50 series support now also includes support for Cortex-A53
    • stepping speed on Cortex-A cores is improved
    • SWD connections are supported over 38-pin Mictor connector and ARM and TI 14-pin JTAG connectors
    Examples
    • new Jython script jython_pmu to demonstrate use of the Performance Monitor Unit (PMU) to count elapsed cycles and user-defined events
    • source code and examples for a Cortex-A9 port of Keil CMSIS-RTOS RTX are included in CMSIS_RTOS_RTX.zip
    The following features are deprecated and might be removed in a future release:
      Simulation models
      • Cortex-A8 simulation model for Emulation Baseboard is deprecated
      Supported host platforms
      • support for Ubuntu Desktop Edition 10.04 LTS is deprecated
      GCC Toolchain
      • GCC toolchain for Linux applications is removed (see the Compilers section in the release notes for information about installing GCC separately
      The following features are removed from this release:
        Examples
        • Linux application examples cpp, cpp_library, cppex, cppex_library and example_library are removed
        • BeagleBoard/xM Linux distributions in the Linux examples are removed
0个回复
您需要登录后才可以回帖 登录 | 注册
本版积分规则
站长推荐上一条 /5 下一条
小黑屋|手机版|Archiver|电子发烧友 ( 湘ICP备2023018690号 )
GMT+8, 2025-1-11 15:17 , Processed in 0.327281 second(s), Total 33, Slave 25 queries .
微信扫描
