各位大神,我想用AVR Atmega128控制LDC1000,但LDC1000总是没有反应,请大家帮忙看看
int main(void) { SPI_MasterInit();//启动SPI Init_IO();//端口初始化 //液晶模块初始化 system_init(); //系统初始化,设置IO口属性 delay_ms(100); LCD_clear(); delay_ms(100); //延时100ms LCD_init(); //液晶参数初始化设置 Init_LDC1000();//LDC1000初始化 while(1) { proximtyData[0] = spi_readByte(LDC1000_CMD_PROXLSB); proximtyData[1] = spi_readByte(LDC1000_CMD_PROXMSB); proximtyDataMAX = ((unsigned char) proximtyData[1]<<8) + proximtyData [0]; conversion(proximtyDataMAX);//将proximtyDataMAX转化为一位一位的字符显示出来 LCD_write_char(0,0,wan); LCD_write_char(1,0,qian); LCD_write_char(2,0,bai); LCD_write_char(3,0,shi); LCD_write_char(4,0,ge); LCD_write_char(6,0,'k'); NOP_1; } } 以上是主程序,下面是我根据LDC1000时序写的读写程序 static unsigned char SpiRead(void) { unsigned char i; for (i=0;i<8;i++) { DATA_BUF=DATA_BUF<<1; SCK_1; if ((PINB&0x07)) //读取最高位,保存至最末尾,通过左移位完成整个字节 { DATA_BUF|=0x01; } else { DATA_BUF&=~(0x01); } SCK_0; } return DATA_BUF; } static void SpiWrite(unsigned char send) { unsigned char i; DATA_BUF=send; for (i=0;i<8;i++) { if (((DATA_BUF&0x80) != 0)) //总是发送最高位 { MOSI_1; } else { MOSI_0; } SCK_1; DATA_BUF=DATA_BUF<<1; SCK_0; } } char spi_writeByte( char addr, char data) { txaddr = addr & ~0x80; CSN_0; SpiWrite(txaddr); SpiWrite(data); CSN_1; NOP_1; return 0; } char spi_readByte(char addr) { txaddr = addr | 0x80; CSN_0; SpiWrite(txaddr); rxbuff = SpiRead(); NOP_1; CSN_1; NOP_1; return rxbuff; } //初始化 void Init_LDC1000() { spi_writeByte(LDC1000_CMD_RPMAX, RPMAX); spi_writeByte(LDC1000_CMD_RPMIN, RPMIN); spi_writeByte(LDC1000_CMD_SENSORFREQ, 0x94); spi_writeByte(LDC1000_CMD_LDCCONFIG, 0x17); spi_writeByte(LDC1000_CMD_CLKCONFIG, 0x02); spi_writeByte(LDC1000_CMD_INTCONFIG, 0x02); spi_writeByte(LDC1000_CMD_THRESHILSB, 0x50); spi_writeByte(LDC1000_CMD_THRESHIMSB, 0x14); spi_writeByte(LDC1000_CMD_THRESLOLSB, 0xC0); spi_writeByte(LDC1000_CMD_THRESLOMSB, 0x12); spi_writeByte(LDC1000_CMD_PWRCONFIG, 0x01); } void Init_IO() { DDRB |= 0XF7; CSN_1; // Spi disable SCK_0; } 请能帮上忙的大神一定帮下忙,万分感谢 如果有任何问题问我,请发邮箱951744011@qq.com |
4 个讨论
875个成员聚集在这个小组
加入小组AVR Atmega16 Bootloader程序与上位机LabView程序
5245 浏览 6 评论
#include <ioavr.h>这个头文件我应该下什么编译器
7843 浏览 0 评论
3122 浏览 2 评论
3167 浏览 1 评论
10195 浏览 1 评论
GMT+8, 2025-2-23 06:05 , Processed in 0.602644 second(s), Total 55, Slave 44 queries .
