请大神看下我的代码,我想让小时段满24进1成00;可是小时段总是满100 进位,请大神指点一下,谢谢
#include #define uchar unsigned char ***it dula = P2^6; ***it wela = P2^7; uchar e0,e1,e2,e3,e4,e5,e6,e7,num,time; uchar code table[] = { 0x3f,0x06,0x5b,0x4f, 0x66,0x6d,0x7d,0x07, 0x7f,0x6f}; void init(); void display(uchar,uchar,uchar,uchar,uchar,uchar,uchar,uchar); void delay(uchar); void main() { init(); while(1) { display(e0,e1,e2,e3,e4,e5,e6,e7); } } void init() { num = 0; time = 0; TMOD = 0x11; TH0 = (65536-91)/256; //9174 TL0 = (65536-91)%256; EA = 1; ET0 = 1; TR0 = 1; } void display(uchar e0,uchar e1,uchar e2,uchar e3,uchar e4,uchar e5,uchar e6,uchar e7) { dula = 1; P1 = table[e0]; dula = 0; P0 = 0xff; wela = 1; P0 = 0x7f; wela = 0; delay(5); dula = 1; P1 = table[e1]; dula = 0; P0 = 0xff; wela = 1; P0 = 0xbf; wela = 0; delay(5); dula = 1; P1 = table[e2]; dula = 0; P0 = 0xff; wela = 1; P0 = 0xdf; wela = 0; delay(5); dula = 1; P1 = table[e3]; dula = 0; P0 = 0xff; wela = 1; P0 = 0xef; wela = 0; delay(5); dula = 1; P1 = table[e4]; dula = 0; P0 = 0xff; wela = 1; P0 = 0xf7; wela = 0; delay(5); dula = 1; P1 = table[e5]; dula = 0; P0 = 0xff; wela = 1; P0 = 0xfb; wela = 0; delay(5); dula = 1; P1 = table[e6]; dula = 0; P0 = 0xff; wela = 1; P0 = 0xfd; wela = 0; delay(5); dula = 1; P1 = table[e7]; dula = 0; P0 = 0xff; wela = 1; P0 = 0xfe; wela = 0; delay(5); } void delay(uchar xms) { uchar i,j; for(i = xms;i>0;i--) for(j = 110;j>0;j--); } void role0() interrupt 1 { TH0 = (65536-91)/256; TL0 = (65536-91)%256; //9174 num++; if(num == 1) { num = 0; time++; e1 = time/10; e0 = time%10; if(time == 1) { time = 0; e2++; if(e2 == 10) { e2 = 0; e3++; if(e3 == 6) { e3 = 0; e4++; if(e4 == 10) { e4 = 0; e5++; if(e5 == 6) { e5 = 0; e6++; if(e6 == 10) { e6 = 0; e7++; if(e7*10+e6 == 24) { e7=0; e6=0; } } } } } } } } } |
4个回答
if(e6 == 10)
{ e6 = 0; e7++; if(e7*10+e6 == 24) { e7=0; e6=0; } } 这段代码要e6 = 10 才能进入,假设e6 =4,e7=2时是进入不鸟这段代码,也就是e7=0;e6=0;永远都执行不了. |
我想做一个多组秒表,你会不?就像体育跑步用的一样
你编的程序我实在是看不懂了,提个建议啊,弄三个变量:小时,分,秒,显示的时候把这三个变量和数码管做个对应就行了,程序看着清楚就不容易出错了~
很明显是看了郭大侠的代码,可以翻看几次视频就明白了
591 浏览 0 评论
377 浏览 0 评论
零知开源——基于STM32F407VET6零知增强板的四路独立计时器
1944 浏览 0 评论
零知开源——STM32F4实现ILI9486显示屏UI界面系列教程(一):电子书阅读器功能
1911 浏览 0 评论
CW32L010 ESC Driver 电机控制套件快速上手指南
1297 浏览 1 评论
13761 浏览 31 评论
GMT+8, 2025-7-19 07:19 , Processed in 0.579804 second(s), Total 76, Slave 59 queries .
