扫一扫,分享给好友
最近在做DSP图像处理,需要将采集到的图像从YCrCb转换成RGB格式后,进行图像处理,再将RGB图像转换成YCrCb进行显示,下面是我的图像处理的程序,不知道为什么显示出来的结果总是一片黑,求高手指点。
void videoReverse() { int i,j,temp; int r,g,b,y,cr,cb,pr,pg,pb; Uint8 *Y,*Cr,*Cb; for(i=intALines;i for(j=intAPixels;j Y=(Uint8 *)(tempYbuffer + i*numPixels + j); Cr=(Uint8 *)(tempCrbuffer + i * (numPixels >> 1) + j); Cb=(Uint8 *)(temPCBbuffer + i * (numPixels >> 1) + j); y=(*Y);cr=(*Cr);cb=(*Cb); y-=16;cr-=128;cb-=128; r=1.164*y+1.596*cr; g=1.164*y-0.813*cr-0.392*cb; b=1.164*y+2.017*cb; if ( r>255 ) r=255; else if ( r<0 ) r=0; if ( g>255 ) g=255; else if ( g<0 ) g=0; if ( b>255 ) b=255; else if ( b<0 ) b=0; temp=2*g-r-b; if ( temp>255 ) temp=255; else if ( temp<0 ) temp=0; r=abs(temp);g=abs(temp);b=abs(temp); pr=abs(0.257*r+0.504*g+0.098*b+16); *(Uint8 *)(tempYbuffer + i*numPixels + j)=pr; pb=abs(-0.148*r-0.291*g+0.439*b+128); *(Uint8 *)(tempCbbuffer + i * (numPixels >> 1) + j)=pb; pr=abs(0.439*r-0.368*g-0.071*b+128); *(Uint8 *)(tempCrbuffer + i * (numPixels >> 1) + j)=pg; Y++;Cr++;Cb++; } } for(i=numLines/2+intALines;i for(j=intAPixels;j Y=(Uint8 *)(tempYbuffer + i*numPixels + j); Cr=(Uint8 *)(tempCrbuffer + i * (numPixels >> 1) + j); Cb=(Uint8 *)(tempCbbuffer + i * (numPixels >> 1) + j); y=(*Y);cr=(*Cr);cb=(*Cb); y-=16;cr-=128;cb-=128; r=1.164*y+1.596*cr; g=1.164*y-0.813*cr-0.392*cb; b=1.164*y+2.017*cb; if ( r>255 ) r=255; else if ( r<0 ) r=0; if ( g>255 ) g=255; else if ( g<0 ) g=0; if ( b>255 ) b=255; else if ( b<0 ) b=0; temp=2*g-r-b; if ( temp>255 ) temp=255; else if ( temp<0 ) temp=0; r=abs(temp);g=abs(temp);b=abs(temp); pr=abs(0.257*r+0.504*g+0.098*b+16); *(Uint8 *)(tempYbuffer + i*numPixels + j)=pr; pb=abs(-0.148*r-0.291*g+0.439*b+128); *(Uint8 *)(tempCbbuffer + i * (numPixels >> 1) + j)=pb; pr=abs(0.439*r-0.368*g-0.071*b+128); *(Uint8 *)(tempCrbuffer + i * (numPixels >> 1) + j)=pg; Y++;Cr++;Cb++; } } } |
兄弟,我们公司需要这样的人才,待遇优厚,有意向请联系:QQ 316047404
4383 浏览 1 评论
848 浏览 0 评论
5801 浏览 0 评论
基于 DSP5509 进行数字图像处理中 Sobel 算子边缘检测的硬件连接电路图
7250 浏览 0 评论
1036 浏览 0 评论
GMT+8, 2025-4-25 19:16 , Processed in 3.408380 second(s), Total 45, Slave 38 queries .
