扫一扫,分享给好友
求助各位大侠下面这段程序中的void image_projecting ()函数该如何进行优化呢?进行线性汇编的话该如何进行代码修改呢?* FILENAME: app_process.c
* PLATFORM: VC6.0 * * The c file is used to compute the projection iamge * * ******************************************************************************/ /*--------------the head file declaration-------------------------------------*/ #include #include #include #include "app_extern.h" #include "app_main.h" /*---------------------------------------------------------------------------------------*/ /*----------------------the function of computing the prejectiong image -----------------* * * * 此函数用于计算该图像的目标放投影图 * * 即:计算图像中每一点成为目标的概率 * * 反投影图中越亮的点表明该点越有可能成为目标 * * 由两部分在组成:1.计算目标的归一化直方图 * * 2.计算各个像素点成为目标的概率 * * 注:本文在图像上建立的坐标系如下图所示 * * * * 0---------------> X(352) * * | * * | * * | * * | * * V y (288) * /-----------------------------------------------------------------------------------------*/ void image_projecting () { object_modeling(Y_data); compute_prob_project(Y_data,Y_shadow); } /*------------------the function of computing the probility of the pixel -----------------* * * * 此函数用来计算图像中各像素点成为目标的概率 * * * /-----------------------------------------------------------------------------------------*/ void compute_prob_project(unsigned char *p_data ,unsigned char*p_data_project) { int i ; unsigned short *prob=Histogram_object; unsigned char temp; for(i=0;i temp=*(p_data++); *p_data_project++=(unsigned char)(*(prob+temp)); } } /*----------------------the function of compute the histogram ---------------------------* * * * 此函数用来计算目标的归一化直方图 * * * /-----------------------------------------------------------------------------------------*/ void object_modeling(unsigned char *p_data) { unsigned short *prob=Histogram_object; int i,j,t; unsigned short x1=object_location_x1; unsigned short x2=object_location_x2; unsigned short y1=object_location_y1; unsigned short y2=object_location_y2; unsigned short scale_window; scale_window=(x2-x1)*(y2-y1); memset(prob,0,512); for(j=y1;j for(i=x1;i *(prob+(*(p_data+j*width+i)))+=1; } } for(i=0;i<256;i++) { *(prob+i)= *(prob+i)*255*3/scale_window; } printf("The object model is constructedn"); } /*-------------------the function of drawing a window around the object ------------------* * * * 此函数用来标注目标在图像中的位置 * * * /-----------------------------------------------------------------------------------------*/ void draw_window (unsigned char *src_data ) { int i ; unsigned short x1=object_location_x1; unsigned short x2=object_location_x2; unsigned short y1=object_location_y1; unsigned short y2=object_location_y2; unsigned short window_w=x2-x1; unsigned short window_h=y2-y1; unsigned char *src; src=src_data+y1*width+x1; /****************标注平行于x轴的框子*************************************/ for(i=0;i *(src+i)=255; *(src+width+i)=255; *(src+i+(window_h-1)*width)=255; *(src+i+window_h*width)=255; } /****************标注平行于y轴的框子*************************************/ for(i=0;i *(src+i*width)=255; *(src+i*width+1)=255; *(src+i*width+window_w)=255; *(src+i*width+window_w-1)=255; } } /*----------------------the function of write the output information --------------------* * * * 此函数用来将所做的题目号和耗费时间加到图像数据中 * * 注:* 请勿修改此项* * /-----------------------------------------------------------------------------------------*/ void fun_out(unsigned char *buffer_in, float costtime) { int j ; unsigned char num = 17; double tt=costtime; for (j = 0 ; j < 10; j ++) { buffer_in[j] = 0; } buffer_in[0] = num; memcpy(&buffer_in[1],&tt,8); } /*********************************** end of the file **********************************************/ |
要沉的节奏吗。。。请求知道的兄弟姐妹们指导一二啊
三条建议:(1)将指针类型,评估占用空间大小,定义为数组类型。 (2)去掉printf语句,使用串口或者iic,上传打印信息。 (3)然后可以评估你使用的dsp或者mcu的空间是否满足你的要求。 期待将你要移植的目标,回复。
基于 DSP5509 进行数字图像处理中 Sobel 算子边缘检测的硬件连接电路图
3344 浏览 0 评论
806 浏览 0 评论
普中科技F28335开发板中,如何使用aic23播放由代码生成的正弦波
3767 浏览 0 评论
4525 浏览 1 评论
1404 浏览 1 评论
GMT+8, 2024-12-26 11:34 , Processed in 0.625680 second(s), Total 75, Slave 58 queries .
