扫一扫,分享给好友
/*****************head file********************/
#include "DSP2833x_Device.h" // DSP2833x Headerfile Include File #include "DSP2833x_Examples.h" // DSP2833x Examples Include File #include "math.h" #include "stdio.h" #include "stdlib.h" // Determine when the shift to right justify the data takes place // Only one of these should be defined as 1. // The other two should be defined as 0. #define POST_SHIFT 0 // Shift results after the entire sample table is full #define INLINE_SHIFT 1 // Shift results as the data is taken from the results regsiter #define NO_SHIFT 0 // Do not shift the results // ADC start parameters #if (CPU_FRQ_150MHZ) // Default - 150 MHz SYSCLKOUT #define ADC_MODCLK 0x3 // HSPCLK = SYSCLKOUT/2*ADC_MODCLK2 = 150/(2*3) = 25.0 MHz #endif #if (CPU_FRQ_100MHZ) #define ADC_MODCLK 0x2 // HSPCLK = SYSCLKOUT/2*ADC_MODCLK2 = 100/(2*2) = 25.0 MHz #endif #define ADC_CKPS 0x0 // ADC module clock = HSPCLK/1 = 25.5MHz/(1) = 25.0 MHz #define ADC_SHCLK 0x1 // S/H width in ADC module periods = 2 ADC cycle #define AVG 1000 // Average sample limit #define ZOFFSET 0x00 // Average Zero offset #define BUF_SIZE 512 // Sample buffer size #define N 180 #define M 140 #define pi 3.1416 #define b 34 //h(n)的序列长度 #define a 40 //h(n)的序列长度 #define c 2*N+b-1 float array_sin[180]; float array_cos[180]; float SampleTable1[BUF_SIZE]={0}; float SampleTable2[BUF_SIZE]={0}; float SampleTable3[BUF_SIZE]={0}; Uint16 SampleTable[BUF_SIZE]; float SampleValue[BUF_SIZE]; float y1[N-1]={0.0}; //输出序列 float y2[c]={0.0}; void InitEPwm1Example(); volatile unsigned int adconvover=0; interrupt void epwm1_timer_isr(void); Uint16 EPwm1TimerIntCount; Uint16 array_index; const float L[34] = { 0, 0.0002864978729488, 0.001264624162909, 0.003083310527426, 0.005841204980407, 0.009575017244339, 0.01425214897781, 0.01976834915372, 0.02595074975146, 0.03256621452731, 0.03933450837311, 0.0459454018102, 0.05207849738032, 0.05742432989344, 0.06170517100719, 0.06469397151492, 0.06623000282249, 0.06623000282249, 0.06469397151492, 0.06170517100719, 0.05742432989344, 0.05207849738032, 0.0459454018102, 0.03933450837311, 0.03256621452731, 0.02595074975146, 0.01976834915372, 0.01425214897781, 0.009575017244339, 0.005841204980407, 0.003083310527426, 0.001264624162909, 0.0002864978729488,0 }; const float H[40] = { -0.001305096054213,-0.001478350963911, -0.00188527402024,-0.002559610054874, -0.003537780947164,-0.004860232357888,-0.006573547322234,-0.008733738690038, -0.01141141434653, -0.01470003343206, -0.01872949362692, -0.02368939446207, -0.02987095372283, -0.03774760142235, -0.0481434027665, -0.06262584473804, -0.08457160676635, -0.1227895346972, -0.2096342344354, -0.6364784631899, 0.6364784631899, 0.2096342344354, 0.1227895346972, 0.08457160676635, 0.06262584473804, 0.0481434027665, 0.03774760142235, 0.02987095372283, 0.02368939446207, 0.01872949362692, 0.01470003343206, 0.01141141434653, 0.008733738690038, 0.006573547322234, 0.004860232357888, 0.003537780947164, 0.002559610054874, 0.00188527402024, 0.001478350963911, 0.001305096054213 }; void LinearConvolution(); void sin_start() { int n=0; float interval =2*pi/180; for (n=0;n<180;n++) { array_sin[n]=sin(interval*n); array_cos[n]=cos(interval*n); } } /***************main function**********************/ main() { Uint16 i; // Clear SampleTable for (i=0; i<200; i++) { SampleTable[i] = 0; // SampleValue[i] = 0; } InitSysCtrl(); //初始化系统函数 InitGpio(); // 该例中跳过 DINT; IER = 0x0000; //禁止CPU中断 IFR = 0x0000; //清除CPU中断标志 InitPieCtrl(); //初始化PIE控制寄存器 InitPieVectTable(); //初始化PIE中断向量表 //服务程序 EALLOW; // This is needed to write to EALLOW protected register //PieVectTable.ADCINT = &adc_isr; PieVectTable.EPWM1_INT = &epwm1_timer_isr; EDIS; InitAdc(); //初始化ADC模块 InitEPwm1Example();//初始化EPwm1模块 array_index=0; EPwm1TimerIntCount=0; //开中断 PieCtrlRegs.PIEIER3.bit.INTx1 = 1;//使能PIE中断,EPWM-T1定时器中断位于INT3.1 IER |= M_INT3; //开CPU中断 EINT; // 使能全局中断 ERTM; // 使能实时中断 // 等待ADC中断 for(;;) { } } void InitEPwm1Example() { EALLOW; SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 0;// 在系统初始化函数中已经使能 //EPWM模块,此处只需设置禁止同步。 EDIS; //1.设置TB模块 EPwm1Regs.TBPRD = 12; //1/(5k*140)ms //设置计数周期=600TBCLK EPwm1Regs.CMPA.half.CMPA = 12500; // 比较器A = 400TBCLK EPwm1Regs.CMPB = 500; //比较器 B = 500 TBCLK EPwm1Regs.TBPHS.half.TBPHS = 0x0000; // 设置相位寄存器置零 EPwm1Regs.TBCTR = 0x0000; // 清除TB计数器 // Setup TBCLK = SYSCLKOUT / (HSPCLKDIV * CLKDIV)=150/4*4 EPwm1Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; //计数方式设置00 //Up-count mode;01Down- count mode;10 Up-down-count mode EPwm1Regs.TBCTL.bit.PHSEN = TB_DISABLE; // 禁止相位加载 EPwm1Regs.TBCTL.bit.PRDLD = TB_SHADOW; //从阴影寄存器加载计数值 EPwm1Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_DISABLE;//禁用同步输出,在头文 //件DSP2833x-ePwm-defines.h中有定义 EPwm1Regs.TBCTL.bit.HSPCLKDIV =TB_DIV4; EPwm1Regs.TBCTL.bit.CLKDIV = TB_DIV4; //设置比较模块 EPwm1Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW; // 映射模式Load registers //every ZERO EPwm1Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW; EPwm1Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO; // load on CTR = Zero EPwm1Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO; // 设置动作模块 EPwm1Regs.AQCTLA.bit.CAU = AQ_SET; EPwm1Regs.AQCTLA.bit.CAD = AQ_CLEAR; EPwm1Regs.AQCTLB.bit.CBU = AQ_SET; EPwm1Regs.AQCTLB.bit.CBD = AQ_CLEAR; //事件触发子模块设置 //1.开始转换脉冲SOCA设置 EPwm1Regs.ETSEL.bit.SOCAEN = 1; // 使能ADC开始转换A(EPWMxSOCA)脉冲 EPwm1Regs.ETSEL.bit.SOCASEL = 2; //设置EPWMxSOCA何时生成,2,TBCTR=TBPRD EPwm1Regs.ETPS.bit.SOCAPRD = 3; //第三个中断事件A发生,即EPWMxSOCA生成 //2.EPWM中断设置 EPwm1Regs.ETSEL.bit.INTSEL = ET_CTR_PRD;//EPWM中断设置,此处设置为周期中断 EPwm1Regs.ETSEL.bit.INTEN = 1; //使能EPWM中断 EPwm1Regs.ETPS.bit.INTPRD = ET_1ST;//第一个事件发生时产生中断 EALLOW; SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 1;// Enable TBCLK within the ePWM EDIS; } void InitAdc(void) { Uint16 i; AdcRegs.ADCTRL1.bit.RESET=1; //复位AD 模块 for(i=0;i<9;i++) {asm(" NOP");} AdcRegs.ADCTRL1.bit.RESET=0; AdcRegs.ADCTRL1.bit.SUSMOD=0; //仿真暂停方式,0为忽略。 AdcRegs.ADCTRL1.bit.ACQ_PS=15; //设定窗口大小SC=ADCTRL1[11:8] + 1 ; //16ADC CLOCKS AdcRegs.ADCTRL1.bit.CPS=1; //内核时钟预定标器,1为二分频 AdcRegs.ADCTRL1.bit.CONT_RUN=1;//连续运行方式,0:启停方式.1:连续转换方式. AdcRegs.ADCTRL1.bit.SEQ_CASC=1; //**级联序列发生器工作方式:0 双序列模 //式;1 级联模式 //ADCTRL3对电源和采样方式进行设置 AdcRegs.ADCTRL3.bit.ADCBGRFDN=3;//带隙参考电路上电 for(i=0;i<10000;i++) {asm(" NOP");} AdcRegs.ADCTRL3.bit.ADCPWDN=1;//除带隙慰嫉缏吠獾钠渌鸄DC模块上电 for(i=0;i<5000;i++) {asm(" NOP");} AdcRegs.ADCTRL3.bit.ADCCLKPS=7; // ADC Core clock divider ://nSPCLK/[2*(ADCTRL1[7]: //CPS+ 1)]=12.5MnZ AdcRegs.ADCTRL3.bit.SMODE_SEL=1; //采样方式。顺序采样0/同步采样1 AdcRegs.ADCMAXCONV.bit.MAX_CONV1=0x07; //设定转换数量,共8同步采样(每 //次采样两个通道),共采样16路 AdcRegs.ADCCHSELSEQ1.bit.CONV00 = 0x0; //采样ADCINA0和ADCINB0 AdcRegs.ADCCHSELSEQ1.bit.CONV01 = 0x1; //采样ADCINA1和ADCINB1 AdcRegs.ADCCHSELSEQ1.bit.CONV02 = 0x2; //采样ADCINA2和ADCINB2 AdcRegs.ADCCHSELSEQ1.bit.CONV03 = 0x3; //采样ADCINA3和ADCINB3 AdcRegs.ADCCHSELSEQ3.bit.CONV08 = 0x4; //采样ADCINA4和ADCINB4 AdcRegs.ADCCHSELSEQ3.bit.CONV09 = 0x5; //采样ADCINA5和ADCINB5 AdcRegs.ADCCHSELSEQ3.bit.CONV10 = 0x6; //采样ADCINA6和ADCINB6 AdcRegs.ADCCHSELSEQ3.bit.CONV11 = 0x7; //采样ADCINA7和ADCINB7 //ADC状态和标志寄存器ADCST(清除中断标志) AdcRegs.ADCST.bit.INT_SEQ1_CLR=1;//中断清除位 AdcRegs.ADCST.bit.INT_SEQ2_CLR=1; //AdcRegs.ADCTRL2.all=0x2800; AdcRegs.ADCTRL2.bit.EPWM_SOCB_SEQ=0; AdcRegs.ADCTRL2.bit.RST_SEQ1=0;// 复位序列发生器1 //SEQ1 AdcRegs.ADCTRL2.bit.INT_ENA_SEQ1=0;//SEQ1中断使能:0禁止,1使能 AdcRegs.ADCTRL2.bit.INT_MOD_SEQ1=0;//SEQ1中断方式:0每个SEQ1序列转换 //束,置位SEQ1的中断标志 AdcRegs.ADCTRL2.bit.EPWM_SOCA_SEQ1=1;//SEQ1的EPWM SOCA使能位,1使能 AdcRegs.ADCTRL2.bit.EXT_SOC_SEQ1=0;//SEQ1的外部SOC信号位 //SEQ2 AdcRegs.ADCTRL2.bit.RST_SEQ2=0; //复位SEQ2 AdcRegs.ADCTRL2.bit.SOC_SEQ2=0; //启动SEQ2的转换触发。仅适用于双序 //列发生器模式 AdcRegs.ADCTRL2.bit.INT_ENA_SEQ2=0; AdcRegs.ADCTRL2.bit.INT_MOD_SEQ2=0; AdcRegs.ADCTRL2.bit.EPWM_SOCB_SEQ2=0; } //**********EPWM1的定时器中断**************** interrupt void epwm1_timer_isr(void)//1S 采样 { Uint16 j,k,mode; float temp1 = 0; float temp2 = 0; // EPwm1TimerIntCount++; //中断次数 //if(EPwm1TimerIntCount==50) // { //EPwm1TimerIntCount=0; //DELAY_US(5L); sin_start(); SampleTable[array_index]= ( (AdcRegs.ADCRESULT0)>>4); SampleValue[array_index] = SampleTable[array_index]*3.0/4096; // If 40 conversions have been logged, start over if(array_index == 140) { LinearConvolution(M,a,SampleValue,H,y1);//线性卷积 mode=0; for(k = 0;k for(j = 0;j temp1 += y1[j]*array_sin[j+k]; temp2 += y1[j]*array_cos[j+k]; } if(mode==0) { SampleTable1[N-1-k] = temp1/(N-k); SampleTable2[N-1-k] = temp2/(N-k); } else { SampleTable1[N-1-k] = temp1/N; SampleTable2[N-1-k] = temp2/N; } } temp1 = 0; temp2 = 0; for(k=0;k SampleTable3[N-1-k]=2*sqrt(pow(SampleTable1[N-1-k],2)+pow(SampleTable2[N-1-k],2)); } for(k = 0;k < N-1;k++) { for(j = 0;j < N-k;j++) { temp1 += y1[j+k]*array_sin[j]; temp2 += y1[j+k]*array_cos[j]; } if(mode==0) { SampleTable1[N-1+k] = temp1/(N-k); SampleTable2[N-1+k] = temp2/(N-k); } else { SampleTable1[N-1+k] = temp1/N; SampleTable2[N-1+k] = temp2/N; } } for(k=0;k SampleTable3[N-1+k]=2*sqrt(pow(SampleTable1[N-1+k],2)+pow(SampleTable2[N-1+k],2)); } LinearConvolution(2*N-1,b,SampleTable3,L,y2);//线性卷积 array_index= 0; } else array_index++; //AdcRegs.ADCTRL2.bit.SOC_SEQ1=0; //EPwm1Regs.ETSEL.bit.SOCAEN = 0; // Reinitialize for next ADC sequence AdcRegs.ADCTRL2.bit.RST_SEQ1 = 1; // Reset SEQ1 //清除定时器中断标志,并使能中断 EPwm1Regs.ETCLR.bit.INT = 1; PieCtrlRegs.PIEACK.all = PIEACK_GROUP3; // AdcRegs.ADCST.bit.INT_SEQ1_CLR = 1; // Clear INT SEQ1 bit //PieCtrlRegs.PIEACK.all = PIEACK_GROUP1; // Acknowledge interrupt toPIE return; } void LinearConvolution(Uint16 xn,Uint16 hn,float *x,float *h,float *y) { Uint16 i,j,k,l; Uint16 yn; //输出序列y的长度 yn=xn+hn-1; for(i=0;i for(i=hn-1;i>0;i--) //将*h作为被乘数 { l=k; for(j=xn-1;j>0;j--) //数组x[n]的1~(xn-1)与h[i]逐一相乘 { y[l]+=h[i]*x[j]; l--; } y[l]+=x[0]*h[i]; k--; } l=k; for(j=xn-1;j>0;j--) { y[l]+=h[0]*x[j]; l--; } y[l]+=x[0]*h[0]; } //=========================================================================== // No more. //=========================================================================== |
我也想弄个,你现在做出来了没,分享点经验吧
2132 浏览 1 评论
756 浏览 0 评论
3640 浏览 0 评论
基于 DSP5509 进行数字图像处理中 Sobel 算子边缘检测的硬件连接电路图
5140 浏览 0 评论
941 浏览 0 评论
GMT+8, 2025-3-11 15:24 , Processed in 0.964441 second(s), Total 74, Slave 57 queries .
