PCB工程英文单词
2013年03月13日 09:45 来源:未知 作者:刘嘉文 我要评论(0) 单词 附件:attached 样品:sample 承认:approval 答复:answer;reply 规格:spec 与...同样的:the same as 前版本:previous version(old version) 生产:production 确认:confirm 再次确认:double confirm 工程问题:engineering query(EQ) 尽快:ASAP(as soon as possible) 生产文件:production gerber 联系某人:contact somebody 提交样板:submit sample 交货期:delivery date 电测成本:ET(electrical test) cost 通断测试:Open and short testing 参考:refer to IPC标准:IPC standard IPC二级:IPC class 2 可接受的:acceptable 允许:permit 制造:manufacture 修改:revision 公差:tolerance 忽略:ignore(omit) 工具孔:tooling hole 安装孔:mounting hole 元件孔:component hole 槽孔:slot 邮票孔:snap off hole 导通孔:via 盲孔: blind via 埋孔:buried via 金属化孔:PTH(plating through hole) 非金属化孔:NPTH( no plating through hole) 孔位:hole location 避免:avoid 原设计:original design 修改:modify 按原设计:leave it as it is 附边:waste tab 铜条:copper strip 拼板强度:panel strong 板厚:board thickness 删除:remove(delete) 削铜:shave the copper 露铜:copper exposure 光标点:fiducial mark 不同:be different from(differ from) 内弧:inside radius 焊环:annular ring 单板尺寸:single size 拼板尺寸:panel size 铣:routing 铣刀:router V-cut:scoring 哑光:matt 光亮的:glossy 锡珠:solder ball(solder plugs) 阻焊:solder mask(solder resist) 阻焊开窗:solder mask opening 单面开窗:single side mask opening 补油:touch up solder mask 补线:track welds 毛刺:burrs 去毛刺:deburr 镀层厚度:plating thickness 清洁度:cleanliness 离子污染:ionic contamination 阻燃性:flammability retardant 黑化:black oxidation 棕化:brown oxidation 红化:red oxidation 可焊性:solderability 焊料:solder 包装:packaging 角标:corner mark 特性阻抗:characteristic impedance 正像:positive 负片:negative 镜像:mirror 线宽:conductor width 线距:conductor spacing 做样:build sample 按照:as per 成品:finished 做变更:make the change 相类似:similar to 规格:specification 下移:shift down 垂直地:vertically 水平的:horizontally 增大:increase 缩小:decrease 表面处理:Surface Finishing 波峰焊:wave solder 钻孔数据:drilling date 标记:Logo Ul 标记:Ul Marking 蚀刻标记:etched marking 周期:date code 翘曲:bow and twist 外层:outer layer 内层:internal layer 顶层:top layer 底层:bottom layer 元件面:component side 焊接面:solder side 阻焊层:solder mask layer 丝印层:legend layer (silkscreen layer or over layer) 兰胶层:peelable SM layer 贴片层:paste mask layer 碳油层:carbon layer 外形层:outline layer(profile layer) 白油:white ink 绿油:green ink 喷锡:hot air leveling (HAL) 水金:flash gold 插头镀金:plated gold edge-board contacts 金手指:Gold-finger 防氧化:Entek(OSP) 沉金:Immersion gold (chem. Gold) 沉锡:Immersion Tin(chem.Tin) 沉银:Immersion Silver (chem. silver) 单面板:single sided board 双面板:double sided board 多层板:multilayer board 刚性板:rigid board 挠性板:flexible board 刚挠板:flex-rigid board 铣:CNC (mill , routing) 冲:punching 倒角:beveling 倒斜角:chamfer 倒圆角:fillet 尺寸:dimension 材料:material 介电常数:Dielectric constant 菲林:film 成像:Imaging 板镀:Panel Plating 图镀:Pattern Plating 后清洗:Final Cleaning 叠层:layup (stack-up) 污染焊盘:contaminate pad 分孔图:drill chart 度数:degree 被…覆盖:be covered with 负公差:minus tolerance 标靶盘: target pad 外形公差:routing tolerance 芯板:core |
【Altium小课专题 第107篇】原理图中批量修改位号或网络标号属性值字体的大小?
11201 浏览 1 评论
【Altium小课专题 第103篇】原理图同一网络颜色进行了设置,但是无法进行显示是什么原因?
8160 浏览 0 评论
【Altium小课专题 第094篇】如何从PCB中直接生成PCB库呢?
8250 浏览 0 评论
【Altium小课专题 第071篇】什么是层次式电路设计?它的优点有哪些?
7032 浏览 0 评论
【Altium小课专题 第068篇】原理图的模板如何进行编辑信息更改?
13359 浏览 0 评论
GMT+8, 2025-4-19 01:48 , Processed in 0.444280 second(s), Total 44, Slave 35 queries .
